Loss of kinetic energy due to heat
The discussion revolves around a problem involving a block on a horizontal table and a ball passing through it, where the ball's speed decreases from v to v/2. The original poster seeks to prove a specific fraction of kinetic energy lost due to heat, expressed in terms of the mass ratio of the ball to the block.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the conservation of momentum and its relevance to the problem. There are questions about how to relate kinetic energy loss to heat and how to incorporate the mass of the block into the equations. The original poster expresses uncertainty about the role of the mass ratio (γ) and how to set up the equations correctly.
Participants are actively engaging with the problem, offering guidance on using conservation of momentum and kinetic energy concepts. There is a recognition of the need to express certain variables in terms of others, and some participants are clarifying the relationships between the different quantities involved. However, there is no explicit consensus on the correct approach or final formulation yet.
There is an ongoing discussion about the assumptions made in the problem, particularly regarding heat loss and the role of the block's mass. Participants are also addressing the need to express results in a specific format as required by the problem statement.
Cocoleia
I have a bloc sitting on a horizontal table, and we shoot a ball through it. The speed right before entering the block is v and the speed when it exits the block is v/2. I need to prove that the fraction of the initial energy that is lost due to heat is 3/4 - γ/4, where γ is mass of ball/mass of block (γ<1)
Conservation of momentum
I know that usually kinetic energy is given by 1/2 mv^2, so then the kinetic energy of the ball once it exits the block will be 1/8 mv^2. I am not sure how to begin with this question.
Hi Coco,
There is always the conservation of momentum to consider. Should have been listed as a relevant equation under item 2 of the template !
BvU said:
Hi Coco,
Ok, I added it. I didn't think about this concept playing a role in the question
Good. Now check your math. the 1/4 is not correct.
Ok, I fixed that too. What I don't understand is how to find the heatloss from the energy or the conservation of momentum. What is the relationship between them ?
:smile: if you keep fixing like that, my comments will make me look dumb ... never mind.
Who mentioned heat loss ? I don't see it in the problem statement !
Yeah, you added it in words. Now work it out in terms of ##\ v_0\ ## and ##\ \gamma\ ##,
I don't quite understand what γ is
##\gamma = m_{\rm ball} / M_{\rm block}##
Would I have to separate this into three parts, before the block, inside the block and after the block? Do I start by working with momentum or kinetic energy?
Questions, questions, questions... :smile:
They tell you the ball speed before the block (##v_0##) and after (##{1\over 2}v_0##).
And they ask for something after the block. So no need to worry about the violent path through the block :rolleyes:
And you have the corresponding kinetic energies of the ball already
I have to correct myself:
It's there bright and clear, sorry o:) .
Note that you are already very close to where you want to be: the ball goes from ##{1\over 2} mv_0^2## to ##{1\over 8} mv_0^2## so 3/4 is the maximum loss due to conversion to heat. Apparently that's overestimated and needs a correction.
I don't get what the mass of the block has to do with the problem, how do i incorporate it in the forumlas? I don't think it will be used for the kinetic energy ?
Can you express the conservation of momentum in ## \ m_{\rm ball} , \ M_{\rm block},\ v_{\rm ball} , \ V_{\rm block}\ ## before the block is hit and after the ball has come out ?
For the KE of what, exactly? [hint]
Before:
mballv
after
mballv/2 + MblockVblock
You have the kinetic energy of the ball before it hits the block, and the conservation of momentum before
after it hits you have the kinetic energy of the ball with the reduced speed and for the conservation of momentum I assume now the block will come into play, but I don't know to tie all of this together.
Yes, and of what else?
Of the block ?
Cocoleia said:
Of the block ?
Yes
haruspex said:
Yes
Will the block be moving at the same speed as the ball? I don't know how to set up the equations
If the ball comes out the other end, then: no.
Not true: you do know. :smile: You did it in your post #14. How many unknowns are there ? Remember ##\gamma = m_{\rm ball} / M_{\rm block}##
Yes, but how do I relate this to the conservation of momentum and how will this lead me to finding my heat loss
Post #14 is conservation of momentum if you equate 'before' and 'after'. It helps you express Vblock in terms of v and ##\gamma##
I am able to get for loss of kinetic energy
3/4mballv^2-1/4Mblockγv
How can I refine this to get rid of the m, M and v (like in the initial question)
If I divide this by the initial kinetic energy I end up with
1/4-(γ^2/2)
which is not what I want, I need to get 3/4-γ/4
1/4-(γ^2/2)
I do not get that from so dividing. In particular, how does the 3 disappear?
Cocoleia said:
##\frac 34m_{ball}v^2-\frac 14M_{block}γv##
That is not quite right. You omitted the power of 2 on the second velocity (γv) and have dropped a factor.
Ok. I fixed the problem. Thanks
  • · Replies 21 ·
  • · Replies 33 ·
