How to Calculate Ton for SiC IGBT Power Devices?
  • Thread starter Thread starter billy fok
    Igbt Power
This discussion focuses on calculating the Ton for Silicon Carbide (SiC) Insulated Gate Bipolar Transistor (IGBT) power devices. The key steps involve determining the gate voltage to optimize the collector-emitter voltage drop and using the junction curves from the datasheet to establish the volt/amp characteristics. Power losses are calculated by multiplying the voltage drop across the collector-emitter (CE) by the current flowing through the gate. Iterative calculations may be necessary to achieve the desired accuracy.
  • Understanding of SiC IGBT operation and characteristics
  • Familiarity with datasheet analysis, specifically for power devices
  • Knowledge of voltage drop calculations in electronic circuits
  • Basic circuit analysis skills to determine current flow
  • Review the IXYS datasheet for the IXGH48N60B3C1 SiC IGBT to understand its specifications
  • Learn about calculating power losses in IGBT devices
  • Study the impact of gate voltage on collector-emitter voltage drop
  • Explore iterative methods for improving accuracy in circuit calculations
Electrical engineers, power electronics designers, and anyone involved in optimizing the performance of SiC IGBT power devices will benefit from this discussion.
billy fok
In power device, there will be losses.. my device is SiC IGBT.
i know how to find Toff = toff + tf base on datesheet..
but i don't know how to find Ton = doff +tr.
http://ixapps.ixys.com/DataSheet/DS100140A_IXGH48N60B3C1.pdf
can someone guide me along..
Read the data sheet and determine what the voltage that you will use to turn on the gate, the larger the voltage, the less voltage is actually seen by the junction across the collector to the emitter is when the device is on. This voltage needs to be determined, then read the voltage from the junction curves to determine the volt/amp curve. Power losses equal the voltage drop across the CE multiplied by the current flow through the gate. Your actual circuit load will determine the current flow which will then be used to determine your loss in the transistor.
You may have to iterate your circuit one or two cycles ie crunch the numbers one or two times to approach the accuracy you need.
15K
9K
