Low Water Pressure in high rise buildings
The discussion revolves around the topic of low water pressure in high-rise buildings compared to ground-level apartments, focusing on the physics principles involved in fluid dynamics and pressure. Participants explore the assumptions related to energy and pressure in a fluid system.
  • Participants discuss the energy required to move water to different heights and question the original poster's assumptions about energy and pressure. They explore the relationship between pressure and height in a fluid system.
The discussion is ongoing, with participants providing insights and questioning assumptions. Some guidance has been offered regarding the relationship between pressure and height in a fluid column, but no consensus has been reached yet.
Participants note that the question pertains to the topic of pressure and its relation to height, indicating a potential misunderstanding of fluid dynamics principles. There is also mention of the original poster's concern about adhering to forum rules.
sco_111
Missing homework template due to originally being posted elsewhere.
Hello, I am learning physics on my own and came across this question about why we would have low water pressure in a high rise apartment compared to an apartment located on ground level. I googled and cannot find a direct explanation.
I took some time to think about the approach and I could only come up with this explanation.
First of all, I assume that the energy used to deliver a fixed amount of water is the same for a low-rise and a high-rise apartment (since water pumps should be working at constant power). Does this assumption make sense?
Secondly, Energy = Force x distance and pressure is proportional to force. Area of taps outlets are the same.
For the same amount of energy, the lowrise apt should receive water at a higher force/pressure as compared to a high rise.
Does that make sense? Anyone has a better explanation?
No, this assumption is wrong. What is the energy required to move 1 kg of water to the bottom floor? What is the energy required to move 1 kg of water to the top floor?
For a fluid in a connected system, what is the relation between the pressure at different heights?
I would understand that the energy required to move 1kg of water to the top flr would be proportionally higher to the height ratio. So, my assumption is incorrect.
This question is part of the Pressure topic and not in fluid dynamics (which I think is advanced). So, I only know about pressure at different heights for a column of water but I think this does not apply here. Any other clues? Thanks.
Why would it not apply?
For a column of water, the pressure is proportional to the height of the column of water. So, at different heights, h1>h2, P(h1)<P(h2).
So, I should think of this in this way.
If I think of the pump as a water body which is situated at a higher level than the building, then this would apply. Is that correct?
Thanks, orodruin for your help. Apologies for flouting some of the forum rules.
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 29 ·
  • · Replies 70 ·
