Magnet repulsive force -- how long does it last?
The discussion centers on the duration of the repulsive force between magnets, exploring whether this force diminishes over time and the factors that might influence it. Participants examine both theoretical and practical aspects of magnet behavior, including permanent and electromagnets, and the effects of external conditions.
- Exploratory
- Technical explanation
- Debate/contested
- Some participants question whether there is a formula to calculate when magnets will stop repelling each other, suggesting a common sense timeframe of one year.
- Others argue that the repulsive force between two magnets remains constant as long as external factors, such as friction, do not intervene.
- It is proposed that the magnetic force behaves similarly to gravitational force, remaining unchanged unless affected by external changes.
- A participant mentions that the repulsive force will not cease until the magnets are destroyed or demagnetized, or until the electrical current in an electromagnet stops.
- Some contributions discuss the stability of magnetic forces, noting that factors like temperature and mechanical impact can affect the alignment of electron spins in permanent magnets, potentially leading to a decrease in magnetic strength over time.
- There is a discussion about the nature of forces at equilibrium, with some participants clarifying the distinction between restoring forces and the forces acting on a pendulum bob.
- References to external sources and literature are made, including discussions on paleomagnetism and the behavior of magnetic forces in various contexts.
Participants express differing views on the longevity of the repulsive force between magnets, with no consensus reached on whether the force diminishes over time or remains constant under ideal conditions. The discussion includes both supportive and opposing viewpoints regarding the factors that influence magnetic strength.
Participants highlight various assumptions, such as the conditions under which magnets operate and the effects of external influences like temperature and mechanical impact. The discussion also touches on the complexities of magnetic behavior, including the role of electron spins and the stability of magnetic forces.
- 3,135
- 1,587
- 2
- 0
Normally how long this repel process will stop?anuttarasammyak said:Two magnets repel and repel force which depends on distance keeps the same forever. Motion of magnets would die due to other factors e.g., friction.
- 23,207
- 7,695
cel123456 said:Normally how long this repel process will stop?
The repulsive force will not stop until the magnets are destroyed/demagnetized (for a permanent magnet) or until the electrical current stops (for an electromagnet).
- 30,538
- 7,519
The magnetic force behaves like the gravitational force. The force of attraction of a mass to the Earth (its weight) stays the same as long as other things don't change. Two permanent magnets will experience the same force between them until 'something' changes. They don't 'get tired', if that's what you are suggesting.cel123456 said:Normally how long this repel process will stop?
- 3,135
- 1,587
Damped oscillation as lectured here might be of your interest.cel123456 said:Normally how long this repel process will stop?
- 30,538
- 7,519
anuttarasammyak said:Damped oscillation as lectured here might be of your interest.
Not really in this discussion. The Energy in the Oscillation will decay but the force pulling the pendulum bob towards Earth at the equilibrium position won't.
- 752
- 1,507
See Paleomagnetismcel123456 said:common sense, how long magnet will stop repel each other?
The oldest rocks on the ocean floor are 200 mya – very young when compared with the oldest continental rocks, which date from 3.8 billion years ago. In order to collect paleomagnetic data dating beyond 200 mya, scientists turn to magnetite-bearing samples on land to reconstruct the Earth's ancient field orientation.
- 1,257
- 1,964
My late wife usually deferred to my EM knowledge except for animism and 'tired magnet' theory. One day a garnet decorated refrigerator magnet popped off the 'fridge and rolled across the kitchen floor.sophiecentaur said:{snip}Two permanent magnets will experience the same force between them until 'something' changes. They don't 'get tired', if that's what you are suggesting.
"Aha", she exclaimed, "It got tired and fell off!", validating her theory.
I countered that only the glue holding the garnet had failed. The flat magnet was still firmly attached to the refrigerator. We literally had to pry the magnet loose when we sold the fridge.
- 752
- 1,507
https://www.duramag.com/techtalk/tech-briefs/do-magnets-have-a-shelf-life/
https://www.duramag.com/techtalk/te...ure-and-demagnetization-from-external-fields/
- 3,135
- 1,587
I see your point. @cel123456 do you share it with @sophiecentaur?sophiecentaur said:The Energy in the Oscillation will decay but the force pulling the pendulum bob towards Earth at the equilibrium position won't.
Say your concern comes from sustainability of magnetic force itself not motion around the equillibrium, because loop current generates magnetic force, the loop current is lost if power to the circuit is lost. Superconducting magnet does not need power supply to keep current but it is fragile and tends to do phase transition to normal mode. Loop current of an electron spin is as stable as its charge but order of collective electron spins which make permanent magnet is disturbed by heat or magnetic field coming from environment. All these factors and more would make generated magnetic force unstable.
sophiecentaur said:Not really in this discussion. The Energy in the Oscillation will decay but the force pulling the pendulum bob towards Earth at the equilibrium position won't.
Pedantic point, but couldn't help myself: the force on the pendulum bob at the equilibrium position is by definition zero, but I guess you mean it's the sum of two oppositely directed forces (weight & magnetic) whose respective [equal] magnitudes at the [fixed] position of equilibrium are the same each time the bob passes through that point.
- 30,538
- 7,519
sophiecentaur said:Haha if you are going to be pedantic then explain, if the force goes to zero, why the bob doesn’t just float away. It’s the RESTORING force that goes to zero. I wrote what I wrote with some care.
Unfortunately here you are being imprecise [e.g. you just say "force", without specifying if you mean a single force or the resultant], so it's hard to tell if what you wrote is correct or incorrect.
The hovering bar magnet is, at any moment, subject to a downward weight force and an upward magnetic force. At the equilibrium position, the weight exactly balances the magnetic force. Displacing the hovering magnet slightly from its equilibrium position results in the magnetic force either slightly increasing or slightly decreasing, so that in either case the resultant force (weight + magnetic) points toward the equilibrium position. [i.e. this resultant force is what you called the restoring force]
Basically I'm saying your original statement is correct only if by "force" you mean the weight only and not the resultant, and I suspect this is what you actually mean.
- 30,538
- 7,519
sophiecentaur said:the force pulling the pendulum bob towards Earth at the equilibrium position won't.
etotheipi said:Basically I'm saying your original statement is correct only if by "force" you mean the weight only and not the resultant, and I suspect this is what you actually mean.
- 30,538
- 7,519
Imo you were trying to play the pedantry game (great fun, of course) and chose the wrong playing field.
sophiecentaur said:Imo you were trying to play the pedantry game (great fun, of course) and chose the wrong playing field.
This is a natural feature of a written-format scientific discussion forum! If there is something vaguely ambiguous then it's good practice to ask for clarification, especially with things like in this thread where it's easy to make conceptual mistakes.
- 8,032
- 870
Assuming you are thinking of permanent magnets, the answer is that the magnet holds electrons spinning about their own axes. If the spin axes are alignedcel123456 said:As we know the magnet will stop to repel each other after some time, is there any formulae to calculate when it will stop? From common sense, how long magnet will stop repel each other? 1years?
the electrons produce "amperian currents" along the magnet's surface which by themselves never reduce in intensity. They effectively see zero resistance.
(A much lesser amount of magnetic field is also produced by the electrons' motion about the nucleus.)
But the axes can be partially misaligned due to temperature, mechanical impact, etc. and then the electron spins don't add so much, producing lower net current and therefore magnetic field.
So, bottom line, if the permanent magnet is kept at low temeperature and not subject to shock etc. then the magnet theoretically almost never loses magnetic strength.
- 1,399
- 1,420
rude man said:electrons spinning about their own axes.
Um, how?
- 8,032
- 870
Also C. Kittel ch. 12, Ferromagnetism and Antiferromagnetism
- 30,538
- 7,519
Electrons have 'spin' and they are charged. That causes them to behave like small electromagnets with a Moment Dipole Moment. But the 'current' in these electromagnets cannot decay. That's a consequence of Quantum Mechanics.weirdoguy said:Um, how?
In most materials, most of the time, the total of electrons with one spin equals the total with the other spin so most materials cannot be permanently magnetised.
- 8,032
- 870
As I understand it, only the spinning electrons at the material's surface produce the magnetic field. Interior electrons cancel each other.sophiecentaur said:Electrons have 'spin' and they are charged. That causes them to behave like small electromagnets with a Moment Dipole Moment. But the 'current' in these electromagnets cannot decay. That's a consequence of Quantum Mechanics.
- 30,538
- 7,519
Can that be correct? Where have you read that?rude man said:As I understand it, only the spinning electrons at the material's surface produce the magnetic field. Interior electrons cancel each other.
If you take a permanent magnet and break it half way, there will be two new poles. Also there is an internal field all the way through.
- 8,032
- 870
What you point out does not negate the idea of surface currents.sophiecentaur said:Can that be correct? Where have you read that?
Yes there is an internal field; that's how a solenoid works ... I see no way in which my description differs in essence from a solenoid.
- 1,399
- 1,420
Well, yes, they have spin, but since when this means that they are spinning around their own axes?
- 8,032
- 870
If I may respond to @sophiecentaur 's post:weirdoguy said:Well, yes, they have spin, but since when this means that they are spinning around their own axes?
Since about 13 billion years ago, the estimate age of the universe.
- 23,879
- 11,349
- 752
- 1,507
- 30,538
- 7,519
And so do the bands of alternating magnetisation in the widening gaps between some tectonic plates. These alternations are due to the new ferrous material coming to the surface and cooling down, aligned with the Earth's magnetic field at the time and then remaining magnetised. The magnetic stripes are evidence of when the Earth's field flips (every couple of hundred thousand years) and the records go back many cycles.Keith_McClary said:
- · Replies 32 ·
- Replies
- 32
- Views
- 4K
- · Replies 11 ·
- Replies
- 11
- Views
- 2K
- · Replies 7 ·
- Replies
- 7
- Views
- 2K
- · Replies 7 ·
- Replies
- 7
- Views
- 2K
- · Replies 7 ·
- Replies
- 7
- Views
- 2K
- · Replies 5 ·
- Replies
- 5
- Views
- 2K
- · Replies 42 ·
- Replies
- 42
- Views
- 4K
- · Replies 3 ·
- Replies
- 3
- Views
- 2K
- · Replies 3 ·
- Replies
- 3
- Views
- 2K
- · Replies 6 ·
- Replies
- 6
- Views
- 3K
