Magnetic field and coplanar loops
10 replies · 3K views · last reply
Jahnavi
The current in the inner loop should flow in anticlockwise direction so as to resist the increase in flux of the external magnetic field .
But how do I deal with the outer loop since there is smaller loop inside it ?
I think current should flow in anticlockwise direction in the outer loop as well .
But none of the options have current flowing in same direction in both inner and outer loops . Also , how do I determine the magnitude of the two currents ?
The problem mentions "a coplanar loop", yet you mention an inner and an outer loop. Is there one rectangular loop of some finite width or two very thin wire loops? Assuming the latter, as you seem to be doing, is the magnetic flux through the outer loop going to be the same with and without the inner loop in place?
I think , yes .
But this is exactly the confusion . What will be the area used while calculating induced EMF in the outer loop ? Is it the area of the outer loop as if the inner loop doesn't exist OR is it the area enclosed by the outer loop minus area enclosed by inner loop ?
Why should it make any difference? (We always assume the self-induced B field is << the externally applied field.)
Good thought.
But none of the options have current flowing in same direction in both inner and outer loops.
3 of the 4 options are likely wrong, don't you think?
Also, how do I determine the magnitude of the two currents ?
Try applying faraday?
While applying Faraday in the outer loop , what area should I use , area of the outer loop OR area of the outer loop minus area of the inner loop ?
@Charles Link , @cnh1995
The area of the outer loop is used to compite the EMF in the outer loop. The resulting currents in the loops are assumed to be small enough that their magnetic fields do not affect the magnetic field appreciably. Additional hint: The current is going to be equal to the EMF divided by the resistance, with the resistance proportional to the length of the loop of wire.
Does the inner loop detract from the flux in the outer loop?
This one needs one additional part to really determine it conclusively: Is ## \frac{xy}{2 (x+y)}>\frac{uv}{2(u+v)} ##, if ## x>u ## and ## y>v ##? (Basically dividing the area (EMF) by the perimeter (resistance). The ratio is proportional to the current). I believe I succeeded in doing an algebraic proof of this result.(##x,y,u,v ## are all >0). ## \\ ## @Jahnavi You might want to prove this yourself to show ## I_2>I_1 ##. ## \\ ## The proof involves one trick, and the rest follows very quickly: ## \\ ## In the inequality above, divide the numerator and denominator on the left side by ## xy ## , and divide the numerator and denominator on the right side by ## uv ## . (The 2's can be canceled to make things simpler). Then analyze the result algebraically.
I assumed the loops were square in which case it is very easlily proved that I2 > I1. But, good point.
It may be worthwhile showing the rest of this proof: ## \frac{xy}{2(x+y)}>\frac{uv}{2(u+v)} ## is (with the divisions as previously mentioned) equivalent to ## \frac{1}{\frac{1}{x}+\frac{1}{y}}>\frac{1}{\frac{1}{u}+\frac{1}{v}} ##. ## \\ ## A little more algebra gives that this is equivalent to ## \frac{1}{u}+\frac{1}{v}>\frac{1}{x}+\frac{1}{y} ##. ## \\ ## The result is ##( \frac{1}{u}-\frac{1}{x} )+(\frac{1}{v}-\frac{1}{y})>0 ## implies that the original equality holds. And this is indeed the case for ## x>u ## and ## y>v ##.
