Magnetic Field Calculation for Point P in a Current-Carrying Wire Configuration
The discussion revolves around calculating the magnetic field at a specific point P due to a configuration of current-carrying wires, with given current and distance parameters. The participants are exploring the application of the Biot-Savart law and its implications for the problem setup.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants are considering the use of the Biot-Savart law for calculating the magnetic field contributions from different segments of wire. There is uncertainty about the appropriate distance variable to use and how to express the unit vector in relation to point P. Some participants question the need for double integration, while others clarify that only one variable needs to be integrated over.
The discussion is ongoing, with various approaches being suggested. Some participants have provided guidance on how to express the distance variable and the unit vector, while others are attempting to clarify their understanding of the integration process. There is a recognition of the need to carefully consider the geometry of the problem and the contributions from each wire segment.
Participants are working within the constraints of a homework assignment, which may limit the information available and the methods that can be used. There is an emphasis on ensuring that the calculations reflect the specific configuration of the wires and the fixed position of point P.
scoldham
What is the magnitude and direction of magnetic field at point P shown in the figure attached if i = 10 A and a = 8.0 cm? Express the answer in vector notation.
[tex]B = \frac{\mu_0I}{2\pi d}[/tex]
I'm really not sure how to approach this one... I considered using Biot-Savart for each segment of wire... but the problem is the distance r varies... furthermore, keeping the vectors separate will be pretty hairy.
Am I approaching this problem wrong? Or is it just a ludicrous amount of work?
The equation that you quoted applies only to a very long (infinite) wire. You have to use Biot-Savart, there is no other way. The four contributions all point in the same direction so the net field is the sum of the four - no need to worry about components here.
The amount of work is not ludicrous if you are systematic about it. Use Biot-Savart to calculate the magnetic field due to a wire segment of length a at arbitrary point (x, y).
For the first segment plug in x = a/4, y = 3a/4. Now imagine the loop rotated 90o clockwise. The second segment then contributes a field with x = 3a/4, y = 3a/4. Rotate two more times to get the third and fourth contributions. Add the four contributions and you are done. :wink:
I not sure what value to use for r in Biot-savart. Could I use a double integral and integrate over r as well considering that it is a changing value?
There is only one variable to integrate over. No double integral is required. Draw yourself a drawing. Put the origin at the leftmost end of the segment. Point P is at (x, y). Consider a current-carrying element ds at distance s from the origin. What is the distance from ds to P? That is your r and the only variable to integrate over is s because x and y are fixed.
If I'm understanding correctly,
[tex]B(\hat r) = \int \frac{\mu_0 I}{4 \pi} \frac{dl \times \hat r}{|r|^2}[/tex]
dl = ds
[tex]\hat r = <x,y>[/tex]
Thus,
[tex]B(<x,y>) = \frac{\mu_0 I}{4 \pi} \int \frac{ds \times \hat r}{|<x,y>|^2}[/tex]
[tex]ds \times \hat r = ds[/tex]
Integrate from 0 to a,
[tex]B(x,y) = \frac{\mu_0 I}{4 \pi} \int^{a}_{0} \frac{ds}{|<x,y>|^2}[/tex]
[tex]= \frac{\mu_0 I}{4 \pi} \frac{a}{|<x,y>|^2}[/tex]
Plug in x, y and thus the contribution to B from the first line segment? Rinse and repeat for each other segment?
This is not correct. The unit vector is in the direction of r which is a vector from ds to point P. As ds moves along the line segment this unit vector changes direction. First you need to express r in terms of x, y and s. Then you need to find unit vector r which is vector r divided by its magnitude.
Does [tex]r = \sqrt{s^2 + \frac{a^2}{16}}[/tex]?
--edit--
Correction: [tex]r = \sqrt{s^2 + \frac{x^2}{16}}[/tex]
Your first equation is correct, the correction is wrong.
This in only one of four equations for r. Each wire segment will be done separately. You need to add an origin to your diagram and draw in the R vector to prevent confusion.
Also, express x and y as a fiction of s (parametric integral).
So, generically speaking,
[tex]r = \sqrt{s^2 + <x,y>^2}[/tex]
where <x,y> will change depending on which segment I'm considering.
I could integrate,
[tex]B(<x,y>) = \frac{\mu_0 I}{4 \pi} \int^{a}_{0} \frac{ds}{|r|^2}[/tex]
using the generic value for r which will produce an equation that gives B as a function of <x,y>.
Because each segment has the same current and length, and only the position of P relative to the segment changes (in terms of <x,y>), carefully plugging in values for <x,y> will give the the B field at P as a result of each segment. Correct?
Actually, neither equation is correct. Look at the drawing. Vector r has magnitude
[tex]r=\left[(s-x)^2+y^2 \right]^{1/2}[/tex]
No reason for that. Please read my initial posting to this thread.
This is incorrect because x and y are fixed. They represent the coordinates of point P. They cnnot depend on where one places element ds.
Almost. S is your variable of integration and P is fixed. You need to express x(s) and y(s) under the root (with the coordinates of P fixed). There will be a different equation for each line segment.
Edit: it's correct. I just saw your new drawing.
I could integrate,
Taking into account that my value for r is incorrect, is this the correct approach?
If I plugged in the correct value for r, this would work?
Thanks for all the assistance so far!
Follow through my postings, look at my drawing and you will see your way through.
  • · Replies 17 ·
