Understanding the Direction of Magnetic Fields in Cartesian Coordinates
The discussion revolves around understanding the direction of magnetic fields in Cartesian coordinates, particularly in the context of cylindrical coordinates and the Biot-Savart law. Participants explore the implications of magnetic fields generated by currents in cylindrical geometries.
  • Participants question the reasoning behind dividing the problem into two cases and the absence of current in the initial setup. There is a focus on understanding the derivation of the theta direction in relation to magnetic fields and the implications of using cylindrical coordinates.
Some participants have offered insights into the nature of inductance and the geometric considerations involved. Others have provided definitions and clarifications regarding the theta direction in cylindrical coordinates. Multiple interpretations regarding the direction of the magnetic field are being explored, with no explicit consensus reached.
There is mention of assumptions regarding current distribution in the problem, as well as the potential complexity introduced by varying current conditions. The discussion also highlights the need for clarity on the directionality of the magnetic field in relation to the geometry presented.
nabliat
here is the problem and solution:
http://i30.tinypic.com/2w2mnap.jpg
why they divide into two cases?
then they find a magnetic field
but we don't have any electricity flowing??
the i recognized the formula for a magnetic field from a wire
but when we find a the formula from the biotsavart law
the only direction is dlX\hat{r}
there is no \vec{\theta} there
because thus in Cartesian coordinates the direction always changes
how they get this theta direction thing??
Remember, inductance is a purely geometrical quantity and is independent of the current flowing in the cable. This means you can apply any current you want, use it to calculate the flux and then divide by that current and the result will be the inductance. In that solution, they simply assume a constant current of I flowing up the inner cylinder and down the outer (uniformly distributed over the surface of each cylinder), which makes the calculation simple. You could just as well choose a time varying current or a non-uniformly distributed current if you like, but the calculation will be more difficult and the end result will be the same.
how to get the theta direction??
the theta direction points in the direction of increasing azimuthal angle, in cylindrical polar coordinates.
\mathbf{\hat{\theta}}=-\sin\theta\mathbf{\hat{x}}+\cos\theta\mathbf{\hat{y}}
this means that the field circles around the wire...there are many derivations of this in pretty much every EM text
i got here a similar solution
http://i29.tinypic.com/hsuhde.jpg
but here they didnt specify whether the direction is with theta or
counter theta
i don't know how to diside that
with this new solution
Use the 'right-hand rule'... point the thumb of your right hand in the direction of a straight current, and your fingers will curl in the direction of the field.
