Magnetic Field in parallel plate capacitor
The discussion centers on calculating the magnetic field in a parallel plate capacitor with an area of 60 cm² and a separation of 3 mm, initially charged at 90 microcoulombs. As the medium between the plates becomes slightly conducting, the charge loss occurs at a rate of 2.5 x 10^-8 C/s. The consensus is that the magnetic field is zero in the direction perpendicular to the plates, while a circulating magnetic field exists parallel to the plates, influenced by the leakage current. The application of Ampere's Law is essential for understanding the magnetic field behavior in this scenario.
  • Understanding of parallel plate capacitors
  • Familiarity with Ampere's Law
  • Knowledge of magnetic fields and current-carrying conductors
  • Basic principles of electromagnetism
  • Study the application of Ampere's Law in various configurations
  • Learn about the behavior of magnetic fields in conducting media
  • Explore the concept of leakage current in capacitors
  • Investigate the effects of capacitor geometry on magnetic field distribution
Students in physics, particularly those studying electromagnetism, electrical engineers, and anyone interested in the behavior of magnetic fields in capacitive systems.
LoveBoy
A parallel plate capacitor of area 60cm^2 and separation 3mm is charged initially at 90 micro coulomb. If the medium between the plates get slightly conducting and the plate loses charge initially at the rate of 2.5 *10^-8 C per sec then what is the magnetic field between the plates?
My Attempt :-
I don't if i am correct or wrong.
I think Magnetic field would be zero at initial condition and final condition . But i don't know how do i calculate magnetic field at any instant ?
My Attempt :-
Welcome to the PF.
Is there a figure that goes along with this problem? There will be a circulating magnetic field around the leakage current lines, but that's parallel to the plates, not "between" the plates (subject to interpretation -- hence my question about the figure)...
Welcome to the PF.
Well there is no figure.Simply a detailed question.Options are not there too.
Well, then I guess we need to assume that "between" means with any orientation, not necessarily pointing between the plates (which the B-field does not do here).
Are you familiar with the calculation of the magnetic fiend using Ampere's Law for the B-field inside and outside a current-carrying wire (assuming a constant current distribution within the wire, which is similar to your problem here)?
Well, i know the formula.But didn't apply at all because I'm in grade 12.
For more information,answer is zero given.
Do they say why? It's not zero in the direction that is parallel to the plates. They must be asking about in the direction of the current, perpendicular to the plates..?
Well this is what i know. Answer is zero and no additional information is given in question.
If we picture the space between the plates as being filled with dozens of conducting (albeit resistive) wires 'shorting' the plates, won't their magnetic fields cancel, except around the fringes of the medium?
Could you please elaborate ?
I believe this situation is the same as the one I mentioned earlier -- it's like when you calculate the B-field strength both inside and outside of a uniform current-carrying wire. It increases with radius until you reach the boundary of the wire, and decreases with r after that. It's calculated via Ampere's Law.
EDIT -- So I believe the full answer is that there is a B-field parallel to the plates, there is none perpendicular to the plates, "between" them...
On reviewing this, I'd say it's likely that the question was set by someone who didn't fully understand what is involved in answering it.
As berkeman says, it involves the application of Amperes Law. The maths is beyond HS level, but there's a graph midway through this article: http://dev.physicslab.org/document.aspx?doctype=3&filename=magnetism_ampereslaw.xml
In summary, the magnetic field is not zero except along the centreline in the gap.
Likes LoveBoy
The magnetic field lines are circles about the center of the plates, and the field strength is proportional to the radial distance away from the center.
This is an approximate statement since the plates' sides are not infinitely large It also assumes that the leakage current is uniform across the area of the plates.
Likes berkeman
  • · Replies 18 ·
  • · Replies 28 ·
  • · Replies 18 ·
  • · Replies 16 ·
14K
