Magnetic field of solenoid and a coil with multiple turns
The discussion revolves around understanding the differences in equations used to calculate the magnetic field of a solenoid compared to a coil with multiple turns. Participants are exploring the physical distinctions between these two types of coils and the implications of their geometries on the equations used.
  • Participants are questioning why different equations apply to solenoids and coils, particularly focusing on the physical differences and the significance of coil length in determining which equation to use. There are inquiries about the thresholds that define when one equation becomes applicable over the other.
The discussion is active, with participants providing insights into the conditions under which different equations are valid. Some guidance has been offered regarding the use of Biot-Savart and Ampere's law, but there remains a lack of consensus on the precise definitions of the thresholds for coil length.
Participants are navigating the complexities of magnetic field calculations, with references to specific conditions under which certain equations are applicable. The conversation includes considerations of the geometry of coils and the transition between different calculation methods.
rooks
Member advised to use the formatting template for all homework help requests
Hi!,
I have a question for you geniuses (geniusi?)
Why are there two different equations to find the magnetic field of a solenoid and a coil with multiple turns?
(According to my textbook)
The equations for each are
Solenoid:
Coil with multiple turns:
Why are they different? Is there a physical difference between a coil and a solenoid?Thanks for the help.
Hello Rooks, :welcome:
Don't double-post, please.
And google a bit before you post: your expressions apply to different kinds of coil: the first one for a long coil
the second for a very short coil
[edit] Google is your friend. Maybe you'll like section 9.4 here
Ok, then where is the threshold? When does a coil become too long to use the 2nd equation? When does a solenoid become too short to use the 1st equation?
Also, I meant why does the length matter and make the equation different?
No threshold but a gradual transition.
There is an intermediate range where neither can be used. The first one stops being useful if the solid angle of the end turn becomes too large.
The second one stops being useful if it's significantly lower than 2 ##\pi##.
You have to use Biot-Savart for "short" coils. You can use Biot-Savart for "long" coils but Ampere's law is usually OK.
You can use Ampere's law if the length of the coil is long enough to warrant ignoring the B field outside the coil.
As BvU say, there is a transition.
And BTW both approaches allow you to determine the B field on the axis, nowhere else.
