How Does an Electron's Path Curve in a Magnetic Field?
An electron with a mass of 9.11 x 10^-31 kg and a charge of -1.60 x 10^-19 C enters a magnetic field of 0.5 T while traveling at 6.50 x 10^6 m/s westward. The magnetic force acting on the electron is calculated to be 5.2 x 10^-13 N. Using the relationship between magnetic force and centripetal force, the radius of the circular path is determined to be 7.40 x 10^-5 m. A suggestion is made to streamline the calculations by combining the equations into a single formula for clarity and efficiency. The discussion concludes with appreciation for the advice and encouragement in physics studies.
Kennedy111
An electron (m= 9.11 x 10^-31 kg) enters a downward magnetic field of 5.00 x 10^-1 T with a velocity of 6.50 x 10^6 m/s West. Calculate the radius of the circular path it will follow when it is traveling within the magnetic field.
m = 9.11 x 10^-31 kg
v = 6.50 x 10^6 m/s West
B = 5.00 x 10^-1 T
q = -1.60 x 10^-19 C
Fm = qvB
Fc = mv^2/r
Fm = Fc
Fm = qvB
= (1.60 x 10^-19 C)(6.50 x 10^6 m/s)(5.00 x 10^-1 T)
= 5.2 x 10^-13 N
Fm = mv^2/r
r = mv^2/Fm
= (9.11 x 10^-31 kg)(6.50 x 10^6 m/s)^2 / (5.2 x 10^-13 N)
= 7.40 x 10^-5 m
I feel like I may have done this question wrong...
It looks good!
May I offer a suggestion?
It is a little more efficient and quite a bit clearer if you write it up this way:
The centripetal force is provided by the magnetic force
Fm = Fc
qvB = mv²/r
qB = mv/r
r = mv/(qB)
Put in the numbers and run it all through the calculator in one go, so no rounding takes place until you write the final answer.
Thank you very much!
I really appreciate your advice as well. :)
Most welcome and good luck with Physics.
  • · Replies 26 ·
