Magnetic field to increase concentration
The discussion revolves around the application of magnetic fields to increase the concentration of gases, particularly in the context of high-temperature gases around 1000°C. Participants explore the feasibility and mechanisms by which magnetic fields might influence gas concentration, touching on concepts such as ion movement and paramagnetism.
  • Some participants question whether a magnetic field can effectively increase the concentration of a gas, especially at high temperatures where molecular motion is significant.
  • There is a suggestion that using a piston in a cylinder might be a more straightforward method for concentrating gas rather than relying on magnetic fields.
  • One participant argues that magnetic fields can influence gas ions, referencing mass spectrometry as an example of how magnetic fields change the route of ions.
  • Another participant challenges the assumption that gas particles, which are typically neutral, can be affected by magnetic fields, emphasizing the need for clarity about the type of gas being discussed.
  • Questions arise regarding the specific conditions under which magnetic fields might affect paramagnetic gases, with oxygen being mentioned as a potential example.
  • There is a call for more detailed specifications regarding the type of magnetic field geometry and the nature of the gas in question to provide a meaningful response.
Participants do not reach a consensus on whether magnetic fields can be used to increase gas concentration. There are competing views regarding the assumptions made about gas behavior and the effects of magnetic fields on different types of gases.
The discussion highlights limitations in the original question, including the lack of specificity regarding the type of gas and the conditions under which magnetic fields might be applied. There is also an acknowledgment that the complexity of the topic may require more detailed exploration than what can be provided in a forum setting.
fysik
can I apply magnetic field to increase concentration of a gas? or I will need too big magnetic field to surpass the 1000C molecular motion?
Not sure what you are thing here. More detail please.
I want to concentrate a 1000C gas in an area
can I apply magnetic field to increase its concentration in that area?
Your re-statement didn't really help. What kind of area? How concentrated? Why do you think that a B-field will have any effect on the gas?
Can you just use a piston in a cylinder to do the concentration?
excuse me, do you have any idea how mass spectometry works?
magnetic fields change the route of gas ions
why not increase the concentration of a gas, is it so illogical?
You didn't specify ions in your original question. That is important information (more of which is needed).
Ions in a gas move in all directions, unlike in a mass spectrometer. What is the reason for an increase in concentration in a particular region? What breaks the symmetry?
I want to increase concentration to increase chemical reaction possibility/rate
Ignoring my better judgement, I am going to respond here even though I am pessimistic that this will sink in.
The problem with your original question here is that it is the type of question that falls under "When did you stop beating your wife?" category.
You wanted to know how you can use magnetic field to increase the concentration of a gas. Note what you just did here. You have implicitly assumed that gas particles can be affected by magnetic field, and so you want to use that to try and somehow increase its concentration by manipulating the gas particles. You have basically assumed the validity of something, and then are trying to apply it.
The assumption that dynamics of gas particles can be affected by magnetic field is wrong! Gas particles are usually neutral particles, i.e. no net electrical charge. What physics are you using here that made you think that it can be affected by magnetic fields? This is your starting point, and it is a starting point that you either misunderstood, or didn't know to be even correct or not! I will criticize you for not doing more to check the validity of your assumption BEFORE you try to apply it to something.
This is why a lot of people are scratching their heads when they read this post. And to be frank, many of the questions you posts in a number of threads are of this nature, where you appear to mix-and-match things that simply made very little sense.
Zz.
why it's wrong assumption?
isn't oxygen paramagnetic?
This was your ORIGINAL QUESTION:
So explain to me where in there did you qualify your question to JUST "paramagnetic gas"? How about I give you argon gas? It is "A GAS" as well, isn't it? It took you how many posts in this thread to finally narrow down your phase space and be SPECIFIC in your question?
Secondly, can you show me the equation of motion of a "paramagnetic" particle in a "magnetic field?" I'm asking this because, as with "a gas", this is too vague and too general. What TYPE of magnetic field geometry do you have in mind?
Zz.
well, you could answer "yes, if the gas is magnetic/paramagnetic"
but it's not only that, what about if the gas is dipoles?
so that's why I didn't specify
I don't know the equation of motion of a paramagnetic particle in a magnetic field, or the type of magnetic field geometry that should be used, this is what I am asking basically
This is the first time you mentioned "paramagnetic." First we thought you were thinking of neutral atoms. Then we thought you were thinking of ions:
Now it's paramagnetic atoms. :headbang:
The problem is that this line of thinking can be continued almost indefinitely. It's impossible to explain every possible effect a magnetic field has on a gas in a forum thread so it is up to you to give us the details so that we can answer your question appropriately. We cannot read your mind.
I'm locking this thread. If you want your question answered, then start a new one and be sure to take the time and make the effort to explain, in as much detail as you can, what you want to know. If you aren't sure about the specifics, or if you want to know about a lot of different situations, then it's usually best to ask if anyone knows any good links, articles, or books on the subject. A forum is an excellent place to ask specific questions, but it is not a replacement for a good textbook on the subject.
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 0 ·
