Magnetic Field with Time Dependence
The discussion focuses on calculating the induced electromotive force (EMF) in a circular coil with 197 turns and a diameter of 4.2 cm, subjected to a time-dependent magnetic field. The correct formula for EMF is |EMF| = N * |change in magnetic flux/change in time|. The user initially miscalculated the conversion from volts to millivolts, resulting in an incorrect answer. After correcting the arithmetic and understanding the conversion factor, the final induced EMF was determined to be 1637.07 mV.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Familiarity with calculating magnetic flux
  • Knowledge of unit conversions between volts and millivolts
  • Basic proficiency in algebra for solving equations
  • Review Faraday's Law of Electromagnetic Induction in detail
  • Practice calculating magnetic flux for various shapes and configurations
  • Learn about unit conversions and dimensional analysis in physics
  • Explore the implications of induced EMF in real-world applications, such as generators
Students studying electromagnetism, physics educators, and anyone involved in electrical engineering or related fields who seeks to understand the principles of induced EMF and magnetic fields.
deenuh20
A magnetic field with the time dependence shown in the figure below is at right angles to a N=197 turn circular coil with a diameter of d=4.2 cm.
What is the induced EMF in the coil at t=7.5ms in mV?
See attached graph
|EMF|= N*|change in magnetic flux/change in time|
First Attempt:
I first found Area by pi*(.042m/2)^2 and got 0.001385m^2. Then, I found the slope of the line between 5 and 10 ms, which was -0.006 T/ms. Then, I multiplied this slope by 7.5ms to see what the magnetic field at 7.5ms was, and I got -0.45T. Then, I used this value to find the magnetic flux which was (0.001385m^2)(-0.045T) and got -6.235*10^-5. Then, I took this value, divided by 7.5ms, and got -0.00831. Then, I multiplied this by 197 and got -1.63707 V. I divided this by 1000 and got -0.001637mV, but this answer is not being accepted.
deenuh20 said:
First Attempt:
Good.
All good, so far. And this is almost all you need.
Hint: You've already calculated the rate of change of the field, so what's the rate of change of the flux?
(The flux doesn't matter--only the rate of change of the flux.)
To find the rate of change of the flux, I did:
(B @ 10ms * Area) - (B @ 5ms * Area) all divided by (10ms-5ms)
(-0.01T*0.001385)-(0.02T*0.001385)/(5ms) and got 4.155*10^-5 as the rate of change of the flux
I then multiplied 4.155*10^-5 by 197, and got 0.008185, which I then divided by 1000, and got 8.18535mV, however, this is still not the right answer.
Is my reasoning flawed or am I missing an essential step?
Your reasoning is fine; check your arithmetic.
Ok, let's try this step by step:
I redid my arithmetic here, and as the rate of change of flux, I now got -0.00831
Is this correct?
Also, Thank you very much for your help!:smile:
Looks good to me. (Units: T/s)
Ok, now that I have the rate of change of flux, in order to find the induced EMF, in mV:
I multiplied the rate of change of flux by the number of turns (197)
(-0.00831 T/s)(197)= -1.63707 V
then to get mV: -1.63707 V/1000 = -0.001637 mV
Correct?
If this is the correct way to do it, it is still the wrong answer when I enter it in my homework online :confused:
I got it! I figured out what I was doing wrong. I had to divide by 10^-3, not 1000, and got 1637.07 mV, which was the right answer. Thanks for all your help!
Check this step. (How many mV in a Volt? :wink: )
(edit: Looks like you figured that out on your own!)
