Magnetic force per unit charge and work done on a proton
physninj
a proton moves with a velocity <6*105,3*105> m/s through a magnetic field given by <.2,.2> T
a. Find the magnetic force per unit charge on the proton
b. Find the work done by this force
Fm=qv x B
For part a, I used a property of the cross product to simply divide the force by the charge
Fm/q=v x B
So by finding the cross product, I believe that I reached the force per unit charge which gives (3/5)*105 N/C
For part b, I know that the charge is moving with constant velocity (no net force). Therefore the work done by the magnetic force must be negative. (some outside force must do work against it?)
I have no idea how I would go about finding the "work done by this force", I almost feel as if there's not enough information provided. Wouldn't I at least need the time period over which to consider?
Thank you.
Fm=qv x B
Fm/q=v x B
So by simply finding the cross product, I believe that I reached the force per unit charge which gives (3/5)*105 N/C
Yes, that looks okay. Your value can be written as 6.0 x 104 N/C
If there were no force, then the work done by that force would be zero, right? But you calculated the force (well, the force per unit charge), and it wasn't zero...
What is the expression that gives the work done by a force? (hint: the vector version). What's the direction of the force with regards the motion of the proton?
No, there's enough information. It has to do with a characteristic of the force that results from how it is generated. Take a close look at how you calculated it.
gneill said:
1. If there were no force, then the work done by that force would be zero, right? But you calculated the force (well, the force per unit charge), and it wasn't zero...
2. What is the expression that gives the work done by a force? (hint: the vector version). What's the direction of the force with regards the motion of the proton?
Thanks so much for your response
1. There is no NET force, if I understand the question statement correctly, because the velocity is constant. No acceleration means no force. I know that the magnetic force is not zero.
2. I know that work=force*distance, I did a search for a vector formula but couldn't find anything I think you are talking about. The direction of the force is perpendicular to the two vectors I crossed, making it in the z direction.
but the proton is not moving in the z direction at all, so how is there any work being done?!?
Is it zero then?
If I'm missing something fundamental I could really use some guidance as to what it is.
Thank you
Consider and compare with circular motion. Consider also that there the velocity is NOT constant, but speed is...they are not the same thing. In uniform circular motion there is a constant force, a continuous acceleration, yet the speed is constant. Why?
What distance is involved in the work formula? The vector version tells you something about how the work is related to the direction of the force and the direction of the displacement...
It's not initially moving in the z-direction...
Thank you
I just read in my book the following statement
"the magnetic force acting on a charged particle can never do work because at every instant the force is perpendicular to the velocity"
So the work is zero like I said.
That is correct. [itex]W = \vec{F} \cdot \vec{d} = Fd\;cos(\theta)[/itex]
The work is zero, but not like you said before. This time your reason is correct :smile:
