Magnetic levitation board not working
12 replies · 2K views
HighTechPower
Hi. I'm designing a magnetic levitation board based on schematics attached herewith. However it does not levitate the magnet. Plz note Q1 is P channel MOSFET. Also note that I used coil L1 as X1 & X2 and coil L2 as Y1 & Y2. Where Xs and Ys represents horizontal & vertical directions respectively. I think the original schematic has label errors for Xs and Ys as that confuse with horizontal and vertical directions otherwise I used same circuit. Another thing that I did not used R14, R16, C3, and C4.
Welcome to PhysicsForums. :smile:
I'm no expert in Maglev, but if you are using AC magnetic field drive, you are intending to lift a conducting object via eddy currents, right? I don't think you lift a magnet using AC magnetic fields...
Hi there. Now I also added the said resistors & capacitors however no success.
and probably a non-magnetic one such as Aluminum?
Good question, but I don't know for sure. The demos that I've seen just used some metal plates, but I don't know if they were ferrous or not. Why would it matter with an AC magnetic field?
Perhaps because AC levitation require interaction with the magnetic field from the current induced in the target object. A ferrous target will be attracted to the exciter magnet probably more strongly than the field from the eddy currents.
@HighTechPower, see if it will levitate a coin.
Referring to sch_4, any idea what the U1,2,3 sensors are? Do they detect light, or magnetic fields, or ?
Also, what are DL1,2,3?
Edit:
Looking at the circuit again I realized that it is a DC position servo. The U1,2,3 sensors are probably light sensors that detect when and how much the suspended object blocks light from the LEDs.
As such, a ferrous object is needed and following the original L1 and L2 connection instructions would be critical. I suggest you try their original configuration.
End Edit
Edit-2:
Also, trying to suspend a magnet will not work. A magnetic object will just spin in space and attract to the stronger field from L1 or, L2. (Might make an oscillator though!)
End Edit-2
Cheers,
Tom
Finally it's success with some changes to the original circuit.
Tom.G said:
Please! Please! Details Please!
Well bro I made changes attached in pic herewith. I simply raised Vcc/2 from 2.5 V to 6 V while keeping signals from hall effect sensors at 2.5 V with this circuit. For this to happen please note that resistors R19 & R23 should be of same value and similarly R18 & R24 should be of same value.
I would like to see an image of the apparatus at work.
Please see attachments.
Earnshaw's theorem proves that it is impossible for a static system using only paramagnetic materials (such as ferromagnetic iron) to levitate stably against gravity.
But we never knew those existed. o_O :cry: :cry:
Anyhow, Glad it works. And thanks for the feedback!
Cheers,
Tom
