What is the process for measuring torque in a magnetic field experiment?
The discussion focuses on measuring torque in a magnetic field experiment involving Helmholtz coils. The key parameters to measure include the strength of the magnetic field, the angle between the magnetic field and the magnetic moment, and the strength of the magnetic moment. The torque is calculated using the formula torque = magnetic moment × magnetic field × sin(Theta). A torsion dynamometer is identified as the device for directly measuring torque in this setup.
  • Understanding of torque and its calculation in physics.
  • Familiarity with Helmholtz coils and their magnetic field properties.
  • Knowledge of magnetic moment and its dependence on current and coil area.
  • Basic principles of experimental physics and measurement techniques.
  • Research the operation and calibration of a torsion dynamometer.
  • Study the principles of magnetic fields generated by Helmholtz coils.
  • Explore methods for measuring angles accurately in experimental setups.
  • Investigate the relationship between current, magnetic moment, and torque in electromagnetic systems.
Students and educators in physics, experimental physicists, and anyone involved in electromagnetic experiments or torque measurement techniques.
quietrain
please refer to this website
http://www.nikhef.nl/~h73/kn1c/praktikum/phywe/LEP/Experim/4_3_04.pdf
bascially it wants me to measure torque as a function of
1) strength of magnetic field between 2 helmholtz current coil (constant b-field)
2) angle between the magnetic field and the magnetic moment
3) strength of the magnetic moment
can anyone enlighten me what the experiment wants me to find exactly?
it seems to be asking me to measure torque, but how do i measure torque?
torque = magnetic moment X mag field = uBsin(Theta)
so since the B-field is constant between the helmholtz current coil,
for 1) i am suppose to vary the current in the coil to produce different strength of constant B-field right?
2) since the conductor is suspended in air, how am i suppose to hold it still to vary the angle? since the b-field of the helmholtz loops are always the same.
3)since B-field is cconstant, i can only vary mag moment, so u = current x area of coil, so since area of coil is constant, i can vary current only
Last but most important, how am i suppose to measure the TORQUE physically? the picture kind of shows a measuring rotating stuff on top but i have no idea what it means?
can torque be measured physically? thanks
The experiment apparatus has a Torsion dynamometer, 0.01 N listed. It is the device above the coils. It measures torque directly. Google "torsion Dynamometer" and the manufacturer name and you can see a close up of the device and download the manual if you like.
thank you very much!
  • · Replies 37 ·
  • · Replies 25 ·
