Calculating Magnetism on Child Homework
  • Thread starter Thread starter NewAgeBerean
    Magnetism
The discussion centers on calculating the maximum possible magnetic flux density near a child sleeping 30 cm from household wiring carrying 3.6 kW of power at 240V r.m.s. The correct approach involves using the formula B = (μ0 * I) / (2π * r) to determine the magnetic field strength, where I is the current calculated from the power and voltage. The participants clarify that the r.m.s. voltage is an average value, and the peak voltage is approximately 1.414 times the r.m.s. value. The confusion arises from discrepancies in the current values used, with one participant concluding that the mark scheme's use of 21.2 A is incorrect.
  • Understanding of AC voltage and current, specifically r.m.s. and peak values.
  • Familiarity with magnetic flux density calculations.
  • Knowledge of Ohm's Law and power equations in electrical circuits.
  • Basic grasp of electromagnetism principles, particularly the relationship between current and magnetic fields.
  • Study the relationship between r.m.s. and peak values in AC circuits.
  • Learn how to calculate magnetic flux density using different current values.
  • Investigate the effects of voltage variations on current in AC systems.
  • Explore common mistakes in electrical calculations and how to avoid them.
Students studying physics, electrical engineers, and anyone involved in electrical safety and design, particularly those interested in the effects of electromagnetic fields on human health.
NewAgeBerean
A child sleeps at an average distance of 30cm from household wiring. The mains supply is 240V r.m.s. Calculate the max possible magnetic flux density in the region of child when the wire is transmitting 3.6 kW of power.
Thats the first part. I don't really understand what r.m.s is and how to convert it to normal V..
VI=P
F=BIL
B= (P U0) / (V 2pi r)
= (3.5 * 10^3)(4pi * 10^ -7) / (240 2pi (0.3))
Getting 9.7 * 10 - 2 - not correct.
rms is just a way of stating the 'average' voltage
Shouldn't flux have units of field/area?
So how can u convert average voltage to actual voltage? on the working out they have a current of 21.2 A. How does that happen?
are my formulas wrong?
It's AC so the 'actual voltage' changes continually - it has an average (in simple terms) voltage of 240V so an average current of 3600W/240V = 15A
Now you need the equation for a field a certain distance from a current carrying wire.
Ok i use
B = (U0)(I)/ 2pi (0.3)
= (4.7*10^-7)(14.58) / 2pi (0.3)
= 3.64*10-6 T
They have 21.2 A. and have B= 1.5*10-5 T
Welcome to PF!
Hi NewAgeBerean! Welcome to PF! :wink:
For AC voltage …
Vrms = Vpeak/√2 = Vaverageπ/2√2 :smile:
(same with AC current … Irms = Ipeak/√2)
so in this case which V do i use - average or peak? Are my previous working out correct? and is the mark scheme answer to the question incorrect? (they used 21.2 A)
The question asks for the maximum possible, not the average. The the peak value is about 1.414 (square root of 2) times the rms (root mean square) value.
In real life the voltage in a circuit varies by plus or minus 10% from the nominal as well. Assuming the load's power remains constant, that could mean extra current if the voltage were low.
Looking at the question again, I'm confused by the use of "power" …
… power varies with voltage in an AC current …
P = V2/R, and so Ppeak = Vpeak2/R, Paverage = Vrms2/R.
What exactly does the question mean? :confused:
Its ok, i found out the answer they have is incorrect. Using P/V to get I gives me around 15A using the r.m.s. and around 10A using the peak value.
They are using a current of 21.2A - where that comes from i don't know.
Obviously they made a mistake.
Thanks for all the replies
  • · Replies 28 ·
