Magnitude of an Electric field on a point by 2 charged spheres
The problem involves calculating the magnitude of the net electric field at a specific point on the x-axis due to two uniformly charged spheres, one positively charged and the other negatively charged, positioned at defined locations. The context is rooted in electrostatics and the behavior of electric fields within and around charged objects.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants discuss the implications of the electric field being zero inside a charged sphere and the distinction between conductors and non-conductors. They explore the application of the shell theorem and how it affects the electric field calculations within the sphere.
The discussion is active, with participants questioning initial assumptions about the electric field inside the charged sphere and exploring how to calculate the electric field contributions from both spheres. Some participants have offered insights into the shell theorem and its relevance to the problem, leading to a deeper understanding of the charge distribution.
Participants are navigating the complexities of electric fields in non-conductive spherical charge distributions and the implications of the shell theorem on the calculations. There is an ongoing examination of how charge is distributed within the spheres and how this affects the net electric field at the specified point.
KayleighK
The left-hand sphere has a positive charge Q and the right-hand sphere has a negative charge -Q . Charge is distibuted uniformly over each of two spherical volumes with radius R. One sphere of charge is centered at the origin and the other at x=2R .
Find the magnitude of the net electric field at the point R/2 on the x-axis
E=[tex]\frac{1}{4\pi\epsilon_{0}}[/tex] ([tex]\frac{Q}{R^{2}}[/tex]
Since the point is located within the first sphere, I thought the electric field would be zero.
Then I typed in:
E=[tex]\frac{1}{4\pi\epsilon_{0}}[/tex] ([tex]\frac{Q}{\frac{3}{2}R^{2}}[/tex]
but it said the answer was wrong. Can anyone please help?
But the sphere is not a conductor. So the field inside a uniformly charge sphere the is not equal to zero.
Oh ok, so then the E field for the first sphere would be:
[tex]\frac{1}{4_{0}\epsilon\pi}[/tex][tex]\frac{Q}{\frac{1}{2}R^{2}}[/tex]
And then since both fields of the spheres are pointing the same direction I will just add the E fields of the first sphere with the second sphere?
Why? The shell theorem states that the part of the sphere from r=1/2R to R creates no net electric field. The sphere "under" that shell has radius 1/2R, so what charge must it have?
Would it have half the charge it originally had? Q/2?
Would it? How much of the original volume does the smaller sphere have?
It would have 1/8 less volume...so then Q/8
Ok, I finally understand the problem now. Thank you so much for your help! I appreciate it =)
