Magnitude of vertical and horizonal componants
The discussion revolves around the calculation of the horizontal and vertical components of a vector given its magnitude and angle. Participants are exploring the relationships between these components using trigonometric functions.
  • Participants discuss the notation and values for the angle and magnitude, with some questioning the correctness of the angle and its measurement reference. There are attempts to calculate the components using trigonometric functions, with varying results and some confusion about the formulas used.
The discussion is ongoing, with participants sharing their calculations and expressing confusion about the results. Some guidance has been offered regarding notation and the use of trigonometric functions, but there is no clear consensus on the correct approach or answers.
There appears to be some uncertainty regarding the angle's value and the proper application of trigonometric functions to find the vector components. Participants are also navigating issues related to notation and calculation methods.
kaydis
Find the magnitude of the vertical and horizontal components of this signal.
6∠(2pi/4) [W]
(∠ = angle)
I'm not too sure where to start, but 6 is the magnitude and (2pi/4) is the angle? So if I were to plot this on a graph I could get the value of the point on the horizontal and vertical axis. I've tried to plot is using graphing software but it wasn't working so I'm not sure if i was doing it correctly. Does anyone have any ideas?
I'm not sure I understand your notation, but if the angle is ##\frac{2\pi}{4}## then that's ##\frac{\pi}{2}##. Are you sure that's correct?
In any case, from what axis is the angle measured?
sorry, i just double checked and its 3π/4
So, what do you know about components (of a vector)?
i know that they're the parts of a vector and that you use trigonometry to find the componants?
Exactly!
so if:
horizontal: Vx = Vcos
vertical : Vy = Vsin
this means that:
Vx = Vcos
= (3π/4)cos6
= 2.262347939
Vy = Vsin
= (3π/4)sin6
= -0.658357257
is this correct?
Btw to insert theta like this θ there is a toolbar above the text box we are writing and one of the options of the toolbar is Insert Symbol which you can use to insert various mathematical symbols.
Alternatively you got to learn to use Latex and type things like this
Code:
 ##\theta##
which will give ##\theta## as output text.
PeroK said:
Are you sure you haven't calculated ##v_x = \theta \cos(v)##?
for Vx=Vcosθ
I got 2.262347939
if I do Vx=θcos(V)
i got -4.242640687
kaydis said:
if I do Vx=θcos(V)
i got -4.242640687
I've never seen anyone do that before. That's definitely a new approach.
how would you do it? sorry I'm super confused :oldconfused:
kaydis said:
for Vx=Vcosθ
I got 2.262347939
if I do Vx=θcos(V)
i got -4.242640687
If you are confused, so am I. I have no idea how you get those answers. I get:
##v_x = v \cos \theta = -4.24##
no I think your right, I swapped them around
