Making a robot to help around my farm
  • Thread starter Thread starter nduka-san
    Robot
38 replies · 5K views
nduka-san
TL;DR
making a robot to help around the farm with 1000 dollars or maybe 2000
i want to make a robot that can plant seeds i made it ina tier of functions i just wana gauge public instrest to see if it would be useful or not and if i should change the measuremetns and the basic control options and anything else you recomend
robots measurements 3 by 2 feet
tier 1 must have
:rake,hoe,shovel to clean the farmland,
fan,to spit seeds out
battery
solar panels
waterproof
control of some kind I am going to say robotic since i think?? that coding is cheaper than useing a remote
by contorl i mean using color sensasors to realized the boudarys of the fields and turn around i would use blue bounardys or red whatevers bright and sticksout
tier 2:realistic addtison i can add with time
water dispenser for watering the seeds
remote for controling it
fertilzer despenser?
camera for watching the fields most likely a raspberry pi camera cause raspberry pis are awesome my guys
tier 3 i somehow get a dono or something and add this
drone budies to rain down fertilizer
some music i gueess
if you see any flaws or would like to suggest somthing let me know and thanks
  • Haha
  • Skeptical
It sounds easier said than done.
How do you know how much it will cost if you haven't built one? How do you know if it will be reliable and maintainable.
If you had a working prototype to demonstrate, it would be more interesting.
What's the difference between this robot and existing agricultural machinery that plants seeds?
its solar powered and small and can be used for personal farms
also i think i could do tier 1 with y budet but do you think its useful or just another run of the mil robot
License your design to iRobot. They've got a Roomba, Poolba, Wallba, and even a Lawnba.
But so far, no CropBa.
  • Haha
Vanadium 50 said:
I don't believe you can do this for $1000. A good lawn mower is $3000, and it does less and runs out of power in under an acre.
While I don't disagree with your conclusion (it'll easily cost an order of magnitude more for R&D alone), I do disagree with your rationale for it.
A lawnmower has a certain minimum power requirement or it can't cut grass at all.
A crop planter has no such minimum power requirement (that I can see). It could, in theory, operate only as fast as its solar panel provided power can accommodate. (Sure, it might take 2 hours of solar power to dig a single hole for a seed, but the OP didn't specify speed as a priority.)
(I grant the distinction is moot. The OP is attempting to design one of the most sophisticated, intelligent devices ever aimed at a consumer market, and power requirements are going to be the least of his troubles.)
It doesn't have to just poke a hold in the ground. It needs to clear the area - "rake,hoe,shovel to clean the farmland" That is very energy intensive. But it could be gas powered. I think the bigger problem is that the OP wants something that does more than a $3000 mower for a third the cost.
I also think the OP doesn't know much about modern first-world farming. A combine costs more than a house. Planters, which are the device most like he describes, are still well into six figures. A $1000 target for a robotic planter is like a $500 target for a self-driving car.
well i know about farming with my hands in my little garden and its going to probably be plowin cause its seems the most energy efficent
are we able to pin comments on this like on discord
Mentors can "pin" popular threads to the top of their respective forums when appropriate. This thread has a ways to go, but don't give up yet... :wink:
nduka-san said:
I want to make a robot that can plant seeds i made it ina tier of functions
nduka-san said:
tier 1 must have
How do you accomplish these tasks now on your farm? Do you have a small tractor that you use to plow and fertilize and seed and water? If so, it may be easier to automate that small tractor with its attachments, rather than trying to build a whole new one.
If you don't use a tractor, do you have an animal that you use to pull the plow?
The problem with horticulture and farming is that everything is seasonal, you must wait for the critical weather and ground conditions, then finish the job overnight.
Intensive hydroponic horticulture in a controlled environment can use robots efficiently because the stages of production can cycle continuously. Production and utilisation of robots is then a continuous process without seasons.
Why use a machine? Marsupials do a really good job of lawn mowing.
Robots for weeding have applications when they apply herbicide to individual weeds in a crop.
If you use robots without some form of wealth distribution, the unemployed people will raid your farm.
later when i have all the stuff put up could we pin the requirment s for the project and stuff
  • Haha
Nope, not here. Good try, though. :smile:
its my gramps farm we use a small tractor but the point is that its a mit think challenge and everythings got to be new
Yeah, but designing and building a robot to drive the existing farm equipment is a lot more cost effective than trying to design and build all-new robotic farm equipment... :wink:
https://image.shutterstock.com/z/st...cyborg-artificial-intelligence-1186373551.jpg
  • Haha
im going to have to get a big battery maybe that can be my dono part
phyzguy said:
If you can build a robot that does everything you say for $1000, you will become very rich.
If he builds a robot
If he can build a robot that does everything he says for $1,000,000 he will still become very rich.
I think I've found a good investment partner for this project...
Not if it's real slow. :)
would you suggest only doing tier one
I would suggest you get further along in designing something before you ask any more questions. I think there is general agreement here that you don't really understand what you are getting into.
i understand enough i know that il have to use 4 motors are probabay 6000 mm battery pak a solar panel to keep on charging it and some other stuff
  • Skeptical
6m is pretty big for a battery. Your robot will be top heavy. 🤔
  • Haha
the problem is its got to be able to hoe the land and its supoosed to be able to be used for multiple types of things
So this is for a school challenge at MIT?
