Making a vehicle go straight on carpet
  • Thread starter Thread starter Kiblur
    Axle Vehicle
The discussion revolves around designing a gravity-powered vehicle intended to travel on a 5-meter long carpet with a shag thickness of about 5 mm. Participants are exploring the implications of axle types (free axle vs. fixed axle) and their effects on the vehicle's ability to maintain a straight path on the carpet surface.
  • Participants are considering the impact of wheel and axle configurations on vehicle stability, particularly in relation to the carpet's shag. There are inquiries about the effectiveness of wider wheels and the potential advantages of using different axle types at the front and back of the vehicle. Some participants question the mechanics of gravity propulsion in both directions.
The conversation is ongoing, with various ideas being proposed regarding axle types and wheel designs. Some participants have suggested experimenting with free body diagrams and smaller scale models to better understand the forces at play. There is no explicit consensus on the best approach yet, but several productive lines of inquiry have been initiated.
Participants are operating under the constraints of a homework project, which includes specific requirements for the vehicle's design and functionality. Concerns regarding the carpet's texture and its effect on vehicle performance are being actively discussed.
Kiblur
The "statement" is a 5 pages long pdf describing a project we have to do. The tl;dr is that we have to build a gravity-powered vehicle that has to do a round trip on narrow strip of carpet. The carpet is 5 meters long with a shag that's about 0.2 in. or 5 mm thick.
There is no equation
There is no solution per se. I am currently in the brainstorming stage and I am looking for advice.
I have to choose between a free axle or a fixed axle for the freewheeling wheels. Either the wheels or the axle will be mounted on bearings. In either case, there will be a way to align this axle to make it parallel with the driving axle.
I am however worried that the shag of the carpet will cause the vehicle to deviate. Am I right to worry about this? It's not a lumpy carpet, but it's carpet. I would like to know which, between a free axle or a fixed axle, would best help the vehicle stay on a straight path in these conditions. I would also like to know about any other factor that might help the vehicle's ability to stay on a straight path besides wheel alignment and making sure that the wheels are the same size, such as wheel width. I'm thinking that perhaps, if the wheels are wider, the vehicle won't sink in the carpet as much, so it might be less affected by the shag of the carpet.
Thank you for your input.
Kiblur said:
Homework Statement: The "statement" is a 5 pages long pdf describing a project we have to do. The tl;dr is that we have to build a gravity-powered vehicle that has to do a round trip on narrow strip of carpet. The carpet is 5 meters long with a shag that's about .2 in. or 5 mm thick.
Relevant Equations: There is no equation
There is no solution per say.
Sorry. "per se".
Pet peeve.
I have to choose between a free axle or a fixed axle for the freewheeling wheels. Either the wheels or the axle will be mounted on bearings. In either case, there will be a way to align this axle to make it parallel with the driving axle. I am however worried that the shag of the carpet will cause the vehicle to deviate. Am I right to worry about this? It's not a lumpy carpet, but it's carpet. I would like to know which, between a free axle or a fixed axle, would best help the vehicle stay on a straight path in these conditions. I would also like to know about any other factor that might help the vehicle's ability to stay on a straight path besides wheel alignment and making sure that the wheels are the same size, such as wheel width. I'm thinking that perhaps, if the wheels are wider, the vehicle won't sink in the carpet as much, so it might be less affected by the shag of the carpet.
I have not done this experiment but I am pretty sure that larger wheels (in either/both dimensions) will definitely improve tracking by minimizing the randomizing effect of the carpet pile.
I am not actually sure what you mean by a free axle versus a fixed axle.
Free axle : The wheels are fixed on the axle and the axle rotates
Fixed axle : The axle is fixed on the frame and the wheels rotate independently on the axle.
Sounds like it has to do quite a tight turn. That suggests a differential on the driving wheels and either toe-in on the steering wheels or maybe a single steering wheel.
How do you plan to make it do the turn at the right point, and through 180°?
The shag has the effect of making it an uphill journey. I think a larger wheel makes the "slope" gentler.
I'm not sure which type of axle would be better, but could you have one of each? One type on front and one on back. Just thinking. Try some free body diagrams of how you think the forces would act on each style of axle. Think about how a disturbance or imbalance would affect each style. If you can, make a smaller scale model to try out.
I don't understand how is it gravity powered in both directions?
It does not need to turn. It will go forward one way and backward the other way. I will simply insert a peg into the driving shaft and wrap the cable with the weight around it in one direction, then wrap it around the peg, then wrap the cable the other direction.
There will be a vertical shaft at the end of which there will be a pulley which will hold a weight on a cable. The cable will be wrapped around the driving axle and the weight will pull on the axle, causing it to rotate. This axle will have to be a fixed axle. As for how it will drive in both direction, see my previous reply.
Ah. It's the wheels that are free, not the axle. Got it.
You might think about using wheels that dig into the carpet a bit to avoid getting deviated very much. Something like sharp gear-shaped wheels or similar...
From a Google Images search on sharp gears:
  • · Replies 18 ·
  • · Replies 20 ·
