Making Magnets: Attracting & Repulsing - Questions Answered
  • Context: High School
  • Thread starter Thread starter Phy6explorer
    Magnets
The discussion centers around the creation and properties of magnets, including how they produce magnetic fields, the differences between attraction and repulsion, and the relationship between magnetism and gravity. Participants explore both natural and man-made magnets, as well as the underlying principles of magnetism.
  • Some participants propose that magnets can be made through methods such as using coils of wire to create solenoids or by exposing ferromagnetic materials to strong magnetic fields.
  • Others argue that all magnets have both a North and South pole, leading to attraction between opposite poles and repulsion between like poles.
  • A participant questions the magnetic properties of iron, suggesting that while it is attracted to magnets, it may not produce a magnetic field itself.
  • There is a discussion about the natural occurrence of magnets and whether certain planetary systems, like Earth's magnetosphere, influence magnetism.
  • Some participants mention that iron is ferromagnetic, meaning it can become magnetized in an external magnetic field and retain that magnetization.
  • One participant speculates that the magnetic properties of iron may relate to its electron structure and the alignment of magnetic domains within the material.
  • Another participant suggests that electrons can be viewed as small magnets due to their spin and orbital motion.
Participants express differing views on the magnetic properties of iron and the mechanisms behind magnetism, indicating that multiple competing views remain. The relationship between magnetism and gravity also appears to be a point of contention.
Some claims about the nature of magnetism and the conditions under which materials become magnetic are not fully resolved, and there are assumptions about the definitions of magnetism and ferromagnetism that remain unclarified.
Phy6explorer
How are magnets made? I mean how are they made to produce a magnetic field? How are some magnets made to attract and some to repel?
And just to know:-
Does magnetism got some connection with gravity? Because practically we can notice some similarities.I think I am asking an answer to silly question but this stuff has been bothering me for quite a number of days.
Magnets can be made but they can also naturally occur.
Magnets that are made are made using coils of wire that make something called a solenoid. There are also electromagnets that can be turned on and off and work much the same way as a solenoid.
All magnets attract and repel at the same time. All magnets have a North and a South pole. If you put two North poles or two South poles together they repel but if you put a North and a South pole together they attract. You may have heard the saying opposites attract. That is the case here.
Magnetism is a different force to gravity.
The most magnetic naturally occurring substance is pure iron.
If you want any more info just ask.
Thanks, but iron is not magnetic is it? Though magnets get attracted to it can we say that it produces a magnetic field ? Can you please tell me how magnets occur naturally? I mean in the case of the man-made one the solenoid is produced by passing an electric current through the coils, but what about the natural ones? Is some natural system in the universe dependent on magnetism?I mean I know that Earth and some of the other planets have a magnetosphere, but is that the reason why magnetism works in the Earth? Does that mean that magnets won't attract in Venus?
Iron is ferromagnetic: http://en.wikipedia.org/wiki/Ferromagnet
Ferromagnetism is the "normal" form of magnetism with which most people are familiar, as exhibited in horseshoe magnets and refrigerator magnets. It is responsible for most of the magnetic behavior encountered in everyday life. The attraction between a magnet and ferromagnetic material is "the quality of magnetism first apparent to the ancient world, and to us today," according to a classic text on ferromagnetism.[1]
Ferromagnetism is defined as the phenomenon by which materials, such as iron, in an external magnetic field become magnetized and remain magnetized for a period after the material is no longer in the field.
In other words, you can turn an ordinary piece of iron into a magnet and it will stay a magnet for a very long time.
I am not entirely sure as to why iron is magnetic but I think it has something to do with its electron structure.
Magnets are made by exposing material, either powdered under pressure as in a manufactured sintered magnet, or as a predisposed object such as a nail or other ferrous material to a force which aligns their internal structure to impose and retain a magnetic field.
The simplest way is by taking ferro (iron based) magnetic materials such as steel, iron, or it's composits and exposing them to a short, but very intense field as is found in the inside of a solenoid. The strength of the magnet made depends to a great extent on the materials used and their composition.
Please note that not all material is magnetically enhancable. Materials like brass for instance are largely magnetically inert. Others, such as Bismuth, are anti-magnetic. Which is to say that they repel all magnetic fields.
As to your last question about magnetism and gravity, while they share similar properties vis-a-vis attraction over a distance, they are different phenomena.
I believe that microscopically it is. An untreated piece of iron is probably made of tiny "grains" each of which is a magnet (iirc they are called "magnetic domains"), but these grains are themselves not all aligned with each other. I think a possible method to help the domains order themselves goes through melting and slowly solidify the iron possibly with some external "help" such as a magnetic field to "suggest" the newly-forming domains to form in a certain direction rather than randomly.
(I should definitely go back and pick my old solid state physics book...)
After all, isn't each electron like a small magnet?
As long as it orbits or spins, yes.
  • · Replies 33 ·
  • · Replies 42 ·
  • · Replies 16 ·
