Calculating Time from 4:1 Mark-Space Ratio @ 10KHz
  • Thread starter Thread starter nathan27th
    electrical ratio
The discussion focuses on calculating time based on a 4:1 mark-space ratio at a frequency of 10 kHz. The total period of the wave is determined to be 100 µs, with the active mark time calculated as 80 µs by applying the formula: (4/5) * 100 µs. The confusion surrounding the term "ratio" is clarified, emphasizing that it represents a division of the total cycle rather than a simple proportion. The calculations confirm that the space time is 20 µs, providing a clear understanding of the duty cycle in this context.
  • Understanding of frequency and period calculations
  • Knowledge of duty cycle and mark-space ratio concepts
  • Basic arithmetic operations involving fractions
  • Familiarity with waveform characteristics in electronics
  • Study the concept of duty cycle in PWM (Pulse Width Modulation)
  • Learn about frequency domain analysis in signal processing
  • Explore the implications of varying mark-space ratios on signal performance
  • Investigate the use of oscilloscopes for visualizing waveforms and duty cycles
Electronics engineers, signal processing specialists, and anyone involved in designing or analyzing PWM signals will benefit from this discussion.
nathan27th
Hi if I had the ratio of 4:1 and the frequency of 10Khz how would I go about finding the time?
Who which what?
Perhaps you could cut back on other activities? It's always hard to find time, but if something is important most people manage. o_O
Another term for the mark space ratio is duty cycle.
At 10kHz, the entire wave is 100µs and the active part (usually the high part) is 4/5th of that, so 80µs.
To get this I divided 1 cycle by 10,000 cycles per second and got 1/10,000 (100µs) of a second. Since the mark space ratio divides the cycle into parts, I divided the active parts of the ratio (4) by all the parts of the ratio (4+1=5) and got 0.8. I then multiplied 100µs times 0.8 and got 80µs.
I wasn't really clear what you are asking, but this might answer your question.
Frequency = 10 kHz. Therefore period, T = 1 / 10k = 100 usec.
Ratio 4:1 could mean ( 4 marks + 1 space ) = 20%
That would give mark time = 4/5 * 100 usec = 80 usec and the space time = 20 usec.
The “ratio of 4:1” is a bit confusable. It might mean 20%, 25%, 75% or 80%.
A “ratio” suggests a simple division, not a relative proportion such as 4:1 = 4 / (4 + 1 ).
  • · Replies 22 ·
  • · Replies 27 ·
