Maryborough meteorite
  • Thread starter Thread starter Astronuc
10 replies · 4K views
Staff Emeritus
2025 Award
Attention @davenn
Man Keeps Rock For Years, Hoping It's Gold. It Turned Out to Be Way More Valuable.
https://www.sciencealert.com/man-ke...ts-gold-it-turned-out-to-be-way-more-valuable
"I've looked at a lot of rocks that people think are meteorites," Henry told Channel 10 News.
In fact, after 37 years of working at the museum and examining thousands of rocks, Henry said only two of the offerings had ever turned out to be real meteorites.
This was one of the two.
"If you saw a rock on Earth like this, and you picked it up, it shouldn't be that heavy," Melbourne Museum geologist, Bill Birch, explained to The Sydney Morning Herald.
The researchers published a scientific paper describing the 4.6 billion-year-old meteorite, which they called Maryborough after the town near where it was found.
Maryborough, a new H5 meteorite find from Victoria, Australia
https://connectsci.au/rs/article/131/1/18/33773/Maryborough-a-new-H5-meteorite-find-from-Victoria
The Maryborough meteorite is a new H5 ordinary chondrite discovered about 2 km south of Maryborough, Victoria, in May 2015. It is a single stone measuring approximately 39 × 14 × 14 cm and with a mass of 17 kg. Plentiful indistinct chondrules are up to 1 mm across in a strongly recrystallised plagioclase-bearing matrix. Olivine and orthopyroxene in both the matrix and chondrules are uniform in composition (Fo80.1Fa19.3Te0.5Ca-ol0.04 and En81.5Fs17.1Wo1.5, respectively). The main metallic phases present are kamacite, taenite and tetrataenite, often forming composite grains with troilite. . . . .
  • Love
Here's the discoverer and the scientist and the ROCK:
cool, not sure that I knew about that one, let alone have a piece of it
thankyou 😍
A 17kg stony meteorite found by chance by a gold prospector outside Maryborough, Victoria, has been identified by Museums Victoria scientists and acquired for the State Collection.
The article was published in July 2019, so hopefully the meteorite is still on display.
https://museumsvictoria.com.au/medi...ictoria-since-1995-comes-to-museums-victoria/
In May 2015, David Hole, a resident of Maryborough, Victoria, found the heavy and mysterious looking rock resting in yellow clay, around 2km out of Maryborough, while prospecting with a metal detector for gold. In 2018, still curious, Mr Hole brought this 38.5cm x 14.5cm x 14.5cm rock to Museums Victoria for identification.
Museums Victoria geologists Bill Birch and Dermot Henry suspected almost immediately that this was a meteorite. While suspected meteorites are often brought by the public to the museum, almost all of them are , in museum parlance, "meteor-wrongs". Following photography, moulding and weighing, analysis on a slice removed for research purposes confirmed that this humble-looking "rock" is an H5 ordinary chondrite meteorite. The term Chondrite means that this meteorite contains tiny crystallised droplets (chondrules), that formed by flash heating of the dust clouds of the early solar system. It was most likely formed in the asteroid belt between Mars and Jupiter.
Bill Birch, Museums Victoria Emeritus Curator in Geosciences, who lead-authored the scientific paper identifying and describing the Maryborough Meteorite (published today in the Proceedings of the Royal Society of Victoria) muses, "When you consider all the events this chunk of rock has experienced since its formation 4.6 billion years ago, it's really mind-boggling that we get the opportunity to hold it and study it today. How good is that?"
The last meteorite found in Victoria was discovered at Willow Grove, Gippsland, in 1995. It is an iron-nickel meteorite, and is named, as are all meteorites, for the location where it was discovered. The most recent Victorian meteorite to be formally described is Ballarat, which was found in the late 1860s, but not confirmed as a meteorite until 2002. It is regarded as a 'fossil' meteorite, because it was found in river gravels buried under basalt, where it had been carried after landing. That meteorite is currently on display in the Dynamic Earth exhibition at Melbourne Museum.
When this meteorite landed on earth is unclear. Carbon 14 testing suggests between 100 and 1000 years ago. While researchers cannot confirm an exact date of landing, multiple meteor sightings in the Maryborough district were reported in local news between 1889 and 1951. The Maryborough Meteorite may have hurtled through our atmosphere fairly recently.
Some data on the Maryborough meteorite
https://www.lpi.usra.edu/meteor/metbull.cfm?code=68619
The Museum in Victoria apparently has 11 meteorites on dispaly.
https://museumsvictoria.com.au/article/eleven-incredible-meteorites/
Apparently there was a meteorite spotted in the sky above Gippsland (east of Melbourne) on 3 November 2025.
Suspected meteor spotted in afternoon sky across Victoria's Gippsland region​
https://www.abc.net.au/news/2025-11-03/suspected-meteor-gippsland-sonic-boom-afternoon-sky/105964144. (Just left of center coming from the top of the frame over the clouds in the first part)
https://www.9news.com.au/national/a...victoria/9c749c2e-2c6b-4dcd-bbdf-e1cacbc32861
The location was over Barnstable and Paynesville, Victoria.
The ROCK? For a pro wrestler, he seems pretty out of shape!
Greg Bernhardt said:
He thought that was gold!?
If the meteorite was sold today, the price would be astronomically high. ;)
The detector response, prior to digging it out to see, could have been for something metal - it has nickel-iron inclusions. Could by why it was high density - felt heavy.
Not familiar with them myself so not sure how the detectors react to gold bearing stones with gold as inclusions rather than distinct gold nuggets - whether similar.
""The Maryborough meteorite is a new H5 ordinary chondrite discovered about 2 km south of Maryborough, Victoria, in May 2015. It is a single stone measuring approximately 39 × 14 × 14 cm and with a mass of 17 kg. ""
Since it is an ordinary chondrite and wasnt an observed fall that was recovered at the time, it's price is
relatively low. Max of around US$1.50/gram ( more likely only US$1.00 / gram.
So 17,000 grams x 1.5 = $25,500 as a max price, US$17,000 as a normal but respectable price :smile:
As an example, my 5.25kg 5,250 grams meteorite cost me US$4200 (80c / gram)
Now if it has been observed and recovered within a short time, days to a week or so. then that would have
upped its price significantly.
If it was a more rarer meteorite, Lunar, Martian, Pallasite or some of the less common asteroid material
then its price could easily be up to US$100 / gram.
cheers
Dave
cheers
Dave
Darn, my joke did not work. "Astronomically high" relates to space. That is a cool meteor you have. Dayum son, $4200 for a space rock? That is still astronomically high, but not as high as gold.
