Mass Balance Approach for a 2-Stage Distillation Problem
The discussion revolves around a mass balance approach for a two-stage distillation problem involving a three-component mixture. Participants are analyzing the flow rates and compositions of the components throughout the distillation process, focusing on the separation of components A, B, and C.
  • Homework-related
  • The initial mass balance calculations for the three components in the feed mixture are presented, with specific molar flow rates for components A, B, and C.
  • One participant confirms the initial approach as looking good, indicating a positive reception to the calculations presented.
  • Another participant expresses uncertainty about the balance of the calculations, presenting their own flow rates and compositions for the outputs of both columns, which do not seem to balance correctly.
  • A request is made for the equations used to solve the second column, indicating a need for clarification on the calculations.
  • A later reply acknowledges a mistake in the calculations and indicates that the issue has been resolved, although the specifics of the correction are not detailed.
Participants do not reach a consensus on the correctness of the initial calculations, as one participant expresses confusion about the balance, while another confirms the initial approach. The discussion includes both agreement on the initial method and disagreement regarding the subsequent calculations.
There are unresolved aspects regarding the specific equations used for the mass balance in the second column, as well as the assumptions made in the calculations. The discussion reflects a progression of understanding, with corrections made along the way.
This discussion may be useful for students or professionals interested in distillation processes, mass balance calculations, and the application of mathematical reasoning in chemical engineering contexts.
Rogue
180kmol/hr of a three component mixture made up of 60 mol % A, 25 mol % B and 15 mol %.
Component A is the most volatile ,component C is the least volatile.
The mixture is to be passed through a 2 stage distillation process.
80% of component C leaves the bottom of the first column in a 90% mixture with component B.
The top product leaving the first column is further separated in the second column to give a top product 95% A and a bottom product 85% B.
Determine the flows out each column and the mol % A in the bottom of the second column.
Assume none of component A leaves at the bottom of column 1 and none of component C leaves at the top of column 2.
Mass Balance Diagram
My approach is to calculate the kmol % of each component in the feed.
Component A = 108kmol /h
B = 45
C = 27
80% of C leaves at the bottom of column 1.
27 x 0.8 = 21.6
This makes a solution 90% C and 10% B,
So 21.6/0.9 = 24 (100% of product leaving bottom of column 1)
So B = 2.4kmol/hIs this the correct starting approach please?
Looks good so far.
Are you sure?
As I follow up ,I can't seem to get it to balance.
For leaving the bottom of column 1 I have:
21.6kmol Component C
2.4kmol Component BFor entering column 2 I have :
5.4 kmol component C
42.6kmol component B
108 kmol component ALeaving the bottom of column 2:
36.21kmol component B
0.99 kmol component A
Leaving the top of column 2:
6.39kmol component B
But, 121.41 kmol component A.
Hence it doesn't balance so I must be doing something wrong? ??
Let's see how you solved column 2. Please show your equations.
Thanks gents.
Realised my mistake, sorted now.
9K
