StandardBanana
- 2
How much difference is there between the mass/charge ratio of ions of the same element? Is it the same, or does it depend on other factors?
The discussion revolves around the mass/charge ratio of ions of the same element, exploring whether this ratio varies and what factors might influence it. Participants also touch upon the concept of isotopes and their relation to the mass/charge ratio.
Participants express differing views on whether the mass/charge ratio is solely dependent on mass and charge, and while some agree that different ions can have different ratios, the discussion remains unresolved regarding the influence of other factors.
There is ambiguity regarding the terminology used, with some participants initially confusing ions with isotopes. The discussion does not clarify the specific conditions under which mass/charge ratios may vary.
Did you mean "ions" of the same element (as noted by the thread title)? Or perhaps "isotopes"?StandardBanana said:How much difference is there between the mass/charge ratio of atoms of the same element? Is it the same, or does it depend on other factors?
Comeback City said:Did you mean "ions" of the same element (as noted by the thread title)? Or perhaps "isotopes"?
Regardless, mass/charge ratio should be solely dependent on those two quantities.
No problem, and sorry for not mentioning before... Welcome to the Forums!StandardBanana said:Yes I do mean ions, thank you for clearing that up
Does this mean that ions of the same element can have different mass/weight ratios?
