Mass dropped with preloaded spring
  • Level: Undergrad
  • Thread starter Thread starter carb
    Mass Spring
4 replies · 3K views
carb
Hello everybody,
I'm trying to figure out how to calculate xadd, the additional compression of a preloaded spring (initially compressed of xp) on which a mass is dropped from a height "h".
I also wonder :
- if the final compressed spring length is the same with or without preload ?
- if the spring receive an additional compression xadd >0 whatever the drop height ? (even at h=0.001 ?)
I have some remembering about my academic studies (Energy conservation laws applied to spring) but I feel quite uncomfortable since I did not practice for a long time. Thanks a lot for any kind of help.
It is not the same.
Yes it does.
Consider the energy of the cylinder, just before the frame hits the ground:
E1 = m*g*(L-xp) + ½*m*v2
Now consider the energy, E2 , when the cylinder has been brought to a halt ( last figure ).
The difference in energies: ( E1 - E2 ) must have been absorbed by the spring, so:
( E1 - E2 ) = ∫xadd Fspring(x) dx
Hello Hesch !
Thanks to your help I did it this way :
E1 (just before hit) = m*g*(L-xp) + ½*m*v2 + ½*k*xp2
with v = √(2*g*h)
E2 (just before rebund phase) = m*g*(L -xp -xadd) + 0 + ½*k*(xp + xadd)2
Then E1 = E2 led me to this factorisation form (xadd as variable) :
½*k*xadd2 + (k*xp - m*g)*xadd - m*g*h = 0
but I actually changed my mind about the study result and decided to get xadd as an input and to find the corresponding height ("how high can I drop the cylinder to get exactly 100% of potential energy absorbed by the spring").
==> h = [½*k*xadd2 + (k*xp - m*g)*xadd] / (m*g)
k: 10 000N/m
m: 1kg
g: 9.81 m/s2
Spring
L: 0.010 m
xp: 0.003 m
xadd_max: 0.006 m (considering a minimal spring contiguous wire height of 0.001 m)
calculation led to h_max = 0.0307m (max height avoiding potential energy causing impact on the ground)
to confirm the results, here is what I got using a mechanism simulation software :
(velocity as initial condition of the dynamic study (just before hit) : v = √(2*g*h) = 776.067 mm/s)
Good to see that lowest reached position is 1mm according to minimal spring height used is previous calculation (contiguous wire)
I hope the results are not accidentally good :nb).
Thanks again Hesch ! :wink:
What ?? So you gave up finding an algebraic solution, and started playing with numbers instead ?
Well, I calculated that
E1 = m*g*(L-xp) + ½*m*2*g*h = m*g*(h+L-xp)
E2 = m*g*(L-xp-xadd)
E1-E2 = m*g*(h+xadd)
Espring = k*(xp*xadd + ½*xadd2 )
More calculations leads to:
½*xadd2 + (xp-1)*xadd - h*m*g/k = 0 ( solve xadd )
I'm not sure if this is correct, but anyway it makes sense that the calculations ends up in a 2. order equation, giving two solutions:
One when the box is dropped with the spring below the mass, the other when the box is dropped upside down. :smile:
Hello Hesch,
I need to re-do your calculations now ;)
Thank you for your help and explanation !
