What Determines the Loss of Contact in a Mass-Spring System?
  • Thread starter Thread starter Kreyopresny
    Box Mass Spring
The discussion focuses on the dynamics of a mass-spring system where a small mass m is placed inside a box of mass M attached to a vertical spring with stiffness constant k. The key equations governing the system include the motion equations for simple harmonic motion: ma + bv + kx = 0, x(t) = Acos(ωt + δ), and their derivatives for velocity and acceleration. The critical factor determining whether mass m remains in contact with box M is the acceleration of the system; if the acceleration exceeds gravitational acceleration, the mass will lose contact. The value of h, the displacement from equilibrium at which contact is lost, can be calculated using these principles.
  • Understanding of simple harmonic motion principles
  • Familiarity with Newton's laws of motion
  • Knowledge of spring constants and their role in oscillatory systems
  • Ability to differentiate and integrate basic motion equations
  • Calculate the critical height h for loss of contact in a mass-spring system
  • Explore the effects of varying spring constants on oscillation behavior
  • Investigate the role of damping in mass-spring systems
  • Learn about energy conservation in oscillatory motion
Students studying classical mechanics, physics educators, and anyone interested in the behavior of mass-spring systems and simple harmonic motion.
Kreyopresny
A small mass m is in a box of mass M that is attached to a vertical spring of stiffness constant k. When displaced from its equilibrium position y0 to y1 and released, it executes simple harmonic motion. Calculate the reaction between m and M as a function of time. Does the
mass m always stay in contact with the box? If not, what determines that it will lose contact with the box? Calculate the value of h as measured from the equilibrium position for which it loses contact.
ma+bv+kx = 0
x(t) = Acos(\omegat+\delta)
v(t) = dx/dt = -A\omegasin(\omegat+\delta)
a(t) = d2x/dt2 = -A\omega2cos(\omegat+\delta/tex])<br /> <br /> <br /> <h2>The Attempt at a Solution</h2><br /> Think this is a bit off, since I know the weight doesn&#039;t stay in contact with the box, or move like it at all, but I&#039;m not sure how to describe it&#039;s movement, especially when the box changes directions and it continues until hitting the other side of the box and being forced to change direction.<br /> <br /> ma+bv+dx = Ma+bv+dx
Kreyopresny said:
Think this is a bit off, since I know the weight doesn't stay in contact with the box, or move like it at all, but I'm not sure how to describe it's movement, especially when the box changes directions and it continues until hitting the other side of the box and being forced to change direction.
They are not looking for anything quite so complicated, such as describing the trajectory of the small mass as it bounces around inside the box.
Start by assuming that the small mass remains in contact with the box. For a given acceleration, what's the contact force between m and M? What tells you when the small mass is about to lose contact?
  • · Replies 21 ·
