Mass in relation to Tangential Force
A child applies a tangential force of 42.4 N on a merry-go-round with a radius of 2.20 m, causing it to reach an angular speed of 0.0870 rev/s in 4.50 seconds. The correct approach involves using the torque formula, τ = Iα, where I is the moment of inertia and α is angular acceleration. It is essential to convert angular speed to radians per second for accurate calculations. The initial attempt at calculating mass was incorrect due to a miscalculation and misunderstanding of torque. After clarifying these points, the problem was successfully solved.
to819
A child exerts a tangential 42.4 N force on the rim of a disk-shaped merry-go-round with a radius of 2.20 m. If the merry-go-round starts at rest and acquires an angular speed of 0.0870 rev/s in 4.50 s, what is its mass?
t=I\alpha
I=.5mr2
42.4=.5*2.22*.8087*m
m=21.665
Would the above be correct? I'm hesitant about entering it as I only have one more attempt to solve this problem. If not would converting the revolutions per second into radians per second be the right thing to do? Anyone see anything I'm missing? Any help is appreciated. Thank you.
There is mistake in your formula.
Firstly, torque formula is \tau = F.R.sin(\theta) (\theta is angle between F and R)
Besides, torque can be found by using this formula: \tau = I. \alpha (\alpha is angular acceleration)
p/s: what is '0.8087' number in your calculation? I don't get it :(
Ah, thank you for that. That number was me mistyping 0.0870. Should I convert the angular speed to radians per second before I solve for angular acceleration or leave it as is?
Try doing dimensional analysis. If you convert to radians, you'll get an angular acceleration in radians/s^2. If you leave it as is, you'll get an acceleration in revs/s^2. Both are correct, but the formula torque=I*alpha requires that alpha be in radians per second squared.
Solved for it correctly thanks to the help of both of you. Thank you both.
  • · Replies 44 ·
  • · Replies 17 ·
