Calculating Mass Moment of Inertia for a Rotating Rod | Homework Help
The discussion focuses on calculating the mass moment of inertia for a rotating rod and determining bearing reactions. The mass moment of inertia for a thin rod is calculated using the equation (1/12)ML², leading to an initial answer of 0.0427, but confusion arises regarding additional components parallel to the z-axis. A correct approach involves using the parallel axis theorem to account for the rod's geometry and mass distribution, ultimately yielding a mass moment of inertia of 0.1706. For the bearing reactions, calculations suggest that the forces at points A and B are approximately 224.59 N, based on the moment about the x-axis. Clarifications on units and the rod's orientation are necessary for accurate calculations.
reckk
hi.i've been asked to post this question here for a concrete answer..
reckk said:
http://img232.imageshack.us/img232/4976/physicswe5.jpg
total mass of the rod = 4m
m = 0.4kg; b = 0.4m; a = 1.0m, n = 800 U/min
rod is thin
i need to find the mass moment of inertia for the rotating rod relative to z-axis..
(1/12)ML²
for the rod which lies on y axis, i could calculate the mass moment of inertia by using the above equation which will lead me to the following answer
(1/12)*2*0.40*0.8² = 0.0427
but what should i do with the other parts of the rod which are parallel with the z-axis?..
or could i apply the following equation?:
(1/24)*M*L²*sin (2φ)
where φ = 45
thx in advance..
the above question has been solved which the answer is 0.1706
and here's the another question that i need a help
reckk said:
here's the last question..
i need to find the bearing reaction on A and B
value given : n = 800/min; m = 0.4kg; a = 1.0m; b = 0.4m
here's my approach to solve the question:
Moment about x-axis:
Mx = 2 Jyz*ω²
= 2ω² ∫ b*(b/2) dm
= 2ω² ∫ b²/2 dm
= ω² * (b²/2) * m
ω = 2(pi)n/60 = 83.776 (1/s)
Mx = 83.776² * 0.4²/2 * 0.4
= 449.18 Nm
FA = FB =
Mx/2a
= 224.59 N
i wonder if i have done the right approach.. i took b/2 as its center of mass.. so i came up with following equation
∫ b*(b/2) dm
and since there's two parts which is parallel to z-axis.. i time the mass moment of inertia with 2..
is this the way to answer the question?.. I'm kind of confused with another method to calculate moment of inertia where the rod has an angle φ to the y-axis..
and here's my another approach
reckk said:
i came up with another approach
J = Jz1 + Jz2
= 2mr²
= 2*0.4*0.4²
= 0.128
Mx = Jω²
= 0.128 * (2(pi)n/60)²
= 898.35 N
FA = FB = Mx/2a
= 449.175 N
so..which one is the right approach? or is there any another approach?
For the first part you need to use the parallel axis theorem. It states the following:
I_{p}=I_{cm} + mk^{2}
Where I_{p} is the mass moment of inertia about any point, I_{cm} is the mass moment of inertia about the object's center of mass, and k is the distance between the object's center of mass and the axis of revolution.
Clean up some of the units before you post.
rod is thin
I'm going to assume that you meant that the mass of the rod is 4kg and the speed of rotation is 800rpm? I am not really sure about that last unit.
Anyways, there will be no moment on the rod (and thus torque on the bar) unless it is accelerating. If it is simply rotating at a constant velocity then the only thing you need to take into consideration is the weight of the rod. Maybe I could help you more if you explained your reasoning verbally.
mass of the rod is 4m.. so the total mass would be 0.4x4 = 1.6 kg..
yup..revolution per minute is 800 rpm.. sry about dat..
and the rod is homogeneous..
for the 2nd question..
it's only the rod which is parallel to the z-axis is to be considered rite?
so to calculate the moment about x axis, i should consider the center of mass of the rod parallel to z-axis..
is it correct?
  • · Replies 21 ·
