JoshuaC
- 3
- 0
You are playing darts in an elevator that is rising at a constant speed. Should you still aim at your target the way you would normally do, or should you aim higher, or lower? Explain.
Vorde said:Ah you are right. But in the period of time during which the dart is in the air, is the dart being pulled up like the rest of the elevator?
dipole said:Note that the problem states the elevator is rising a constant speed, and hence is not accelerating.
Vorde said:Doesn't what I'm saying still matter though? If it is rising at a constant speed it means there is an acceleration equal to 9.8 m/s^2 up. The dart, in midair, doesn't feel this acceleration.
Drakkith said:No, there is no acceleration if the velocity is constant.
Vorde said:Of course, but the second the 'dart' leaves the thrower's hand, it's no longer being pushed up by the force of the rising elevator cart (mediated by your hand) and therefore it feels a downward force equal to g, right?
JoshuaC said:You are playing darts in an elevator that is rising at a constant speed. Should you still aim at your target the way you would normally do, or should you aim higher, or lower? Explain.
Drakkith said:It already feels a force downward equal to g before the throw. (Just like a dart supported by someone on the ground) Once it is released it is rising at the same velocity as the rest of the elevator and will act identically to a dart thrown on the ground.
davenn said:NO, :)
read the several previous comments, The speed is constant, there is NO acceleration :)
Dave
