Master Power Switch for 3 Circuits?
A user is seeking advice on creating a master power switch for three separate LED circuits powered by USB sources. They inquire whether connecting all circuits in parallel to one switch would damage the USB ports. Responses indicate that the user's description lacks clarity, making it difficult for others to provide useful suggestions. A recommendation is made to research digital control of multiple power MOSFETs for potential solutions. The discussion highlights the importance of clear communication in forums for effective assistance.
WeAreBorrg
Hello all,
Long story short:
I'm modding a Netbook PC; I'm powering three different sets of LEDs from three separate USB power sources.
1. How can I create one master power switch for all three circuits?
2. Would hooking all three circuits up to one switch in parallel burnout my USB ports?
I appreciate any and all constructive commentary.
Also, I understand that your time is valuable and if don't want to be bothered to explain the answer I would be more than happy to receive a very brief answer which would point me in the right direction for my own research.
Thank you in advance.
*...cricket...cricket...
Unless someone can think of something better, I guess I will just have to use a 3 pole, 3 position ceramic rotary switch as a master power switch for all three circuits...
"Long story short" is not sufficient for others to make any useful suggestions. It is not possible (for me, anyway) from your verbal description to visualize exactly what “modding” you are trying to accomplish. You’ve not provided a simple basic block diagram of your planned modification specifications, so members here can only guess and or speculate about your plans. Per your request, I'll try to point you in a direction where you may expect to find some useful suggestions. Google is your friend. Using the search terms “digital control of multiple power mosfets” there are lots of examples of circuits that do similar operations that you’re asking about. For instance, here’s just one:
http://www.ti.com/lit/an/slvu171/slvu171.pdf
You should not need any more info than I have given you. If the info provided is too abstract and not sufficient for you then clearly you cannot be of use.
Is "resistance futile" as well?
Thanks for the defacto useless argumentative forum response. And who says forums are a complete waste of time?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
