Math Challenge - July 2019
101 replies · 20K views
I think #86 is not sufficient. We still need the other direction: image of a cyclic subspace is an ideal or else there are potential well-definedness problems of the supposed isomorphism of lattices. Right now, we have
[tex] I \text{ ideal} \implies T^{-1}(I) \text{ cyclic}[/tex]
We'd also need
[tex] C\text{ cyclic} \implies T(C) \text{ ideal}[/tex]
Put
[tex] T : \mathbb F_q^n \to \mathbb F_q[x] / (x^n-1) =:R,\ (a_0,\ldots, a_{n-1}) \mapsto a_0 + \sum _{k=1}^{n-1} a_kx^{k}[/tex]
Let [itex]C \subseteq \mathbb F_q^n[/itex] be cyclic. We show [itex]T(C)[/itex] is an ideal. As [itex]C[/itex] is a subspace and [itex]T[/itex] is compatible with addition, [itex]T(C)[/itex] is a subgroup. Take [itex]r_0 + \sum_{k=1}^{n-1}r_kx^k\in R[/itex] and [itex]a_0 + \sum_{k=1}^{n-1}\in T(C)[/itex]. We must show their product is in [itex]T(C)[/itex].
[tex] \begin{align*}<br /> &\left (r_0 + \sum_{k=1}^{n-1}r_kx^k\right ) \left (a_0 + \sum_{k=1}^{n-1}a_kx^k\right ) \\<br /> =&r_0\left (a_0 + a_1x + a_2x^2 + \ldots + a_{n-1}x^{n-1}\right ) \\<br /> +&r_1\left (a_0 + a_1x + a_2x^2 + \ldots + a_{n-1}x^{n-1} \right )x \\<br /> +&r_2\left (a_0 + a_1x + a_2x^2 + \ldots + a_{n-1}x^{n-1}\right ) x^2 \\<br /> &\vdots \\<br /> +&r_{n-1} \left ( a_0 + a_1x + a_2x^2 + \ldots + a_{n-1}x^{n-1} \right )x^{n-1}.<br /> \end{align*}[/tex]
As [itex]C[/itex] is a subspace, it is closed w.r.t multiplying by [itex]r_k[/itex]. We also saw in #86 that multiplying by [itex]x^k[/itex] shifts the coefficients, but [itex]C[/itex] is cyclic, thus closed w.r.t shifting. All of the additives are in [itex]T(C)[/itex], therefore [itex]T(C)[/itex] is an ideal.
We'd also need
Put
Your solution seems fine to me now. Well done!
Solution to problem 13.
Proof by contradiction. Suppose all the 3 products, ##u(1 - v), v (1 - w) and w(1 - u)## are greater than ##1/4##. Then it follows that:
##u(1 - v) > 1/4 \Rightarrow u > 1/4(1-v) \Rightarrow (1 - u) < 1 - 1/4(1-v)\;\;\; \mathcal (Eq. 1)##
##v(1 - w) > 1/4 \Rightarrow v > 1/4(1-w) \Rightarrow (1- w) > 1/4v \Rightarrow w < 1 - 1/4v\;\;\; \mathcal (Eq. 2)##
From (Eq. 1) and (Eq. 2), it follows that
##w(1-u) < (1 - 1/4(1-v)) \cdot (1 - 1/4v) = ((3 - 4v) / 4(1 - v)) \cdot (4v - 1) / 4v \\
= (3 - 4v) (4v - 1) / 16v(1-v) = (12v - 3 - 16v^2 + 4v) / 16v(1-v) \\
= (16v - 16v^2 - 3) / 16v(1-v) = (16v(1-v) - 3) / 16v(1 - v) \\
= 1 - 3 / 16v(1-v)##
It it easy to see that for RHS to have maximum value, the denominator of the subtracted value should be maximal. It is trivial to show that ##v(1-v)## reaches maximum when ##v\; =\; 0.5## and therefore the maximum value of RHS would be ##1 - 3 / (16 \times 0.5 \times (1 - 0.5)) = 1/4##. It follows that ##w(1 - u) < 1/4##, disproving the initial assumption that all 3 products could be greater than ##1/4##
You can save some steps in that proof:
Assume there are u,v,w such that all three expressions are larger than 1/4. Then the product of the three expressions must be larger than 1/43 = 1/64.
That product is u(1-u)v(1-v)w(1-w). All factors are positive, to find its maximum we can maximize u(1-u), v(1-v) and w(1-w) individually. The maximum is 1/4 each, the product is 1/64, contradiction.
I gave my take on 13 in #42. Relies on how I like to prove statements of the form ##A_1\lor A_2\lor \ldots \lor A_n##. Equivalently, one can prove
[tex] \neg A_1\land \ldots\land \neg A_{n-1} \implies A_n.[/tex]
fresh_42 said:
My proof uses ##u(1-u)=\frac{1}{4}-(u-\frac{1}{2})^2< \frac{1}{4}## since squares are positive.
Wow. That is the simplest proof for that question!
##\leq## as u=1/2 is possible - squares can be zero. I didn't go into detail with that part as it is very easy to show and a well-known result, too.
I think that's just a typo.
fresh_42 said:
Hey, I was lazy: "<" is on the keyboard ##"\leq"## is not. These details are trivial and left to the reader ;-)
That reminds me of a statistics course lecture. The lector said something like "..and since ##f## is injective, it is invertible..". Similarly, in algebra, saying something is a subgroup of ##G## is to be read as "is an isomorphic copy of a subgroup of ##G##".
or omitting "almost everywhere" in measure theory.
I have also seen isomorphic for monomorphic (here, not in books), which I really dislike.
