Mathemathical pendulum with springs
  • Thread starter Thread starter skrat
    Pendulum Springs
4 replies · 2K views
skrat
A body with mass ##m## is hanged on a line with length ##l## and attached to springs in point ##p##. Point ##p## can move only horizontally. In equilibrium position, non of the springs is deformed. Now let's give that body just a little push out of equilibrium position. Calculate the frequency of oscillation.
Let's put the origin of our coordinate system in point ##p## with ##\hat{i}## axis to right along the right spring and ##\hat{j}## axis pointed up.
Now the coordinate is fixed, while point ##p## can move along axis ##\hat{i}##. Let ##\vec{r} ## be vector from the origin to mass ##m## and let's say that ##\varphi ## is the angle between the line ##l## and vertical line.
Than ##\vec{r}=(lsin\varphi + x,lcos\varphi )## where ##x## is the expansion/shrinkage of springs or in other words: movement of point ##p##.
Than ##\dot{\vec{r}}=(\dot{\varphi }lcos\varphi+\dot{x},-l\dot{\varphi }sin\varphi)## and ##\dot{\vec{r}}^2=(\dot{\varphi }l)^2+2\dot{\varphi }l\dot{x}cos\varphi+\dot{x}^2##.
Now ##L=T-V=\frac{1}{2}m\dot{\vec{r}}^2-(-mglcos\varphi +kx^2)=(\dot{\varphi }l)^2+2\dot{\varphi }l\dot{x}cos\varphi+\dot{x}^2+mglcos\varphi -kx^2##
If that is ok, than
##\frac{\partial L}{\partial \varphi }-\frac{\mathrm{d} }{\mathrm{d} t}\frac{\partial L}{\partial \dot{\varphi }}=\ddot{\varphi }+\frac{g}{l}sin\varphi +\frac{\ddot{x}}{l}cos\varphi =0## and
##\frac{\partial L}{\partial x}-\frac{\mathrm{d} }{\mathrm{d} t}\frac{\partial L}{\partial \dot{x }}=\ddot{x}+\frac{2k}{m}x+\ddot{\varphi }lcos\varphi -\dot{\varphi }^2lsin\varphi =0##
Hopefully so far everything is ok. Now I am lost here. I am somehow supposed to solve this system of differential equations yet I have no idea how. I tried applying Taylor expansion for small ##\varphi ## but that didn't really help much...
Some help, please?
Taylor expanding for small [itex]\varphi[/itex] and [itex]\dot{\varphi}[/itex] helps enormously. Take the expansion up to linear order and you get a set of two coupled linear equations of motion which you can solve with standard methods, finding the eigensystem of solutions.
Yup, I figured it out yesterday late into the night...
For small angles:
##\ddot{\varphi }+\frac{g}{l}\varphi +\frac{1}{l}\ddot{x}=0## and
##\ddot{x}+\frac{2k}{m}x +l\ddot{\varphi }=0##
Now let's say that ##x=x_0e^{i\omega t}## and ##\varphi =\varphi _0e^{i\omega t}##. This gives me
##\begin{bmatrix}
-\omega ^2+\frac{g}{l} & -\omega ^2\\
-\omega ^2& -\omega^2 +\frac{2k}{m}
\end{bmatrix}\begin{bmatrix}
\varphi _0\\
x_0
\end{bmatrix}=\begin{bmatrix}
0\\
\end{bmatrix}##
And finally ##\omega ^2=\frac{g/l}{1+\frac{mg}{2kl}}##
THANKS!
Hm, aren't there two resonance frequencies? You must have a solution with four free parameters, determined by the initial conditions [itex]x(0)=x_0[/itex], [itex]\dot{x}_0=v_0[/itex], [itex]\varphi(0)=\varphi_0[/itex], and [itex]\dot{\varphi}(0)=\Omega_0[/itex].
I don't know. I am not smart enough, that's why I am here learning. :D You tell me?
I do have some unofficial solutions for this problem and my solution is the same. That's all I know.
Maybe I wasn't clear enough when writing the problem: It says here that we grab the mass and pull it away from equilibrium position for small ##\varphi ## and than release it. Does this change anything?
