MATLAB Matlab fsolve: Solving a System of Non-Linear Equations - Need Help!"
  • Thread starter Thread starter duff8000
    Matlab
The discussion revolves around solving a system of 29 non-linear equations in MATLAB, with the user expressing challenges due to limited experience. The user has created two m-files: one for defining the equations and another for setting initial guess values in a matrix format. They encounter errors when attempting to use the fsolve function, specifically related to the way variables are passed to the function. The user seeks clarification on the correct syntax for fsolve and troubleshooting advice for the errors encountered. Responses emphasize the importance of checking error messages provided by MATLAB, suggesting that the user review the fsolve documentation for proper usage and syntax, as well as ensure that all required variables are correctly defined and passed to the function.
duff8000
Hey all, new here, lookin for some help with matlab, pretty much no experience.
Gotta solve a system of 29 non-linear equations so here is what i was thinkin. I made a m-file with func which has each "guess/starting point" set to a variable. Then this function puts all of these into a matrix just so its easier to change and move around etc. Then my other m-file (as shown) has all the equations. Dont know if you can take a matrix as "IN" or what I am doing wrong but keeps thrown errors so any help would be much appreciated...thanks in advance (Also what is the syntax/code for fsolve once i get this workn)?
I had it set so i would call the other function, create a matrix with all those value and pass it to the one below (prolly not best most efficient but I am not too good at all this)
function f = HWFive (A)
m1=A(1);
m2=A(2);
m8=A(3);
m10L=A(4);
m10V=A(5);
m14=A(6);
T2=A(7);
T4=A(8);
T5=A(9);
T6=A(10);
T7=A(11);
T10=A(12);
T12=A(13);
T13=A(14);
cp4=A(15);
cp13=A(16);
P4=A(17);
P13=A(18);
h5=A(19);
h6=A(20);
h6g=A(21);
h7=A(22);
h8=A(23);
h10L=A(24);
h10V=A(25);
h11=A(26);
h12=A(27);
mpropane=A(28);
methylene=A(29);
%Well Here It Goes...
% T-Joint No.1
f(1) = m1-m2+m14;
f(2) = m1*290-m2*T2+m14*320;
%Compressor No.1
f(3) = (P4/1000)-7.5+150.5*((m2*T2^0.5)/1000);
%Propane Evaporator
f(4) = (230 - T4)/100 + exp((-2.64/(m2*cp4)));
f(5) = cp4-2.114-0.000188*P4+(1.76*10^-8)*P4^2;
%Heat Exchanger No.1
f(6) = m2*cp4*(T4-T5)-m14*cp13*(T13-T12);
f(7) = ((T13 - T12)/(T4 - T12)) - ((1 - exp((-4.22/(m14*cp13)*(1 - ((cp13*m14)/(cp4*m2))))))/(1 - ((cp13*m14)/(cp4*m2))*exp((-4.22/(m14*cp13)*(1 - ((cp13*m14)/(cp4*m2)))))));
f(8) = cp13 - 2.114 - 0.000188*P13 + (1.76*10^(-8))*(P13)^2;
%Compressor No.2
f(9) = (1000/P13) - 5.6 + ((142.8*m14*T13^0.5)/P13);
%Heat Exchanger No.2
f(10) = m2*(h6 - h7) - m14*(h12 - h11);
f(11) = 1 - exp((-5.275*(T6 - T7))/(m2*(h6 - h7))) - ((T6 - T7)/(T6 - T12));
f(12) = h6 + 219.6 - 7.025*T6 + (0.034965*(T6)^2) - (0.00011321*(T6^3));
f(13) = h7 + 219.6 - 7.025*T7 + (0.034965*(T7)^2) - (0.00011321*(T7^3));
f(14) = h12 - 790.13 + 4.0137*T12 - (0.058268*(T12)^2) + (0.00019465*(T12^3));
f(15) = log(P13) + (1026/T12) - 13.8;
%Storage Tank
f(16) = m10L + m10V - m8;
f(17) = m8*h8 - m10L*h10L - m10V*h10V;
f(18) = h10L + 219.6 - 7.025*T10 + (0.034965*(T10^2)) - (0.00011321*(T10^3));
f(19) = h10V - 790.13 + 4.0137*T10 - (0.058268*(T10^2)) + (0.00019465*(T10^3));
f(20) = log(101) + (1026/T10) - 13.8;
%T-Joint No.2
f(21) = m2 - m14 - m8;
f(22) = h11 - h7;
f(23) = h8 - h7;
%Ethylene Evaporator
f(24) = m2*(h5 - h6) - 42.2*(T6 - 170);
f(25) = h5 - h6g - cp4*(T5 - T6);
f(26) = h6g - 790.13 + 4.0137*T6 - (0.058268*(T6^2)) + (0.00019465*(T6^3));
f(27) = log(P4) + (1026/T6) - 13.8;
%Other Mass Flow Rates
f(28) = (mpropane)*427.8 - (m2*cp4*(T2 - T4));
f(29) = (methylene)*800.1 - m2*(h5 - h6);
In order to help you were going to need to know what errors its giving you. Matlab is usually pretty good about telling you what is wrong and why when errors occur. Also check Matlab Central or the file exchange. A lot of your work may already be done for you.
Alrite was workn on it a bit newest code is posted below (not really sure if i changed much)
function f = HWFivexx (m1,m2,m8,m10L,m10V,m14,T2,T4,T5,T6,T7,T10,T12,T13,cp4,cp13,P4,P13,h5,h6,h6g,h7,h8,h10L,h10V,h11,h12,mpropane,methylene)
% T-Joint No.1
f(1) = m1-m2+m14;
%Compressor No.1
%Propane Evaporator
%Compressor No.2
%Storage Tank
%T-Joint No.2
f(22) = h11 - h7;
f(23) = h8 - h7;
In the command window i first define all the vars, then call the function
answer=fsolve('HWFivexx',m1,m2,m8,m10L,m10V,m14,T2,T4,T5,T6,T7,T10,T12,T13,cp4,cp13,P4,P13,h5,h6,h6g,h7,h8,h10L,h10V,h11,h12,mpropane,methylene)
It tells me ---
Error in ==> HWFivexx at 47
Error in ==> fsolve at 193
fuser = feval(funfcn{3},x,varargin{:});
So i thought i had a problem with missing a variable when declaring it or something I thought I had Checked Pretty good for this ... is that what this error means for sure?
Oh yea forgot to say that in order to check, i type " methylene " in the command window and it pops out with the correct value that I assigned...dont kno if this means anything tho...
Its telling you that there is an error with the command "fsolve" which is the source of the problem. Look up the help document for this command ("help fsolve") and read its requirements. Chances are there is something wrong with your syntax or your asking it to do something that it can't.
