Matrices, Markov, simple question - to make sure im on right track please
  • Thread starter Thread starter Ush
    Matrices Track
The discussion revolves around a system of components that require regular maintenance to avoid failure. The state vector at the end of month "t" is defined as Vt = [ft, mt, at]T, where ft represents failed components, mt represents components out for maintenance, and at represents components in active production. The problem involves understanding the equations governing the transitions between these states over time, specifically the relationships between the fractions of components that fail or are taken offline for maintenance.
  • Participants attempt to articulate the reasoning behind the equations governing the system, including the definitions of ft+1, mt+1, and at+1. There is a focus on forming a matrix representation of the system and understanding its implications for steady-state behavior.
Some participants express uncertainty about their matrix formulation and whether they are on the right track. There is an acknowledgment of the need to identify eigenvalues related to steady-state conditions, with one participant suggesting that λ = 1 is an eigenvalue based on their observations of the matrix.
Participants are working under the constraints of homework guidelines, which may limit the amount of direct assistance they can receive. There is a shared understanding that the initial conditions involve all components being functional, and the discussion includes the implications of various fractions (p and q) on the system's dynamics.
Ush
there are 13,200 components that must be regularly maintained or else they fail.
At the end of month “t”, there are is a state vector describing the components given by Vt = [ft, mt, at]T
where ft is the number of failed components, mt is the number of components out for maintenance, and at is the number of components in active production.
Of the active components one month ( at ), p is the fraction that fail the next
month, and q is the fraction that have been taken off-line for maintenance. The rest
remain active. All those in maintenance one month ( mt ) are active the next month. All
those that have failed one month ( ft ) are under maintenance the next.
Describe in words why the equations that drive this system are:
Ft+1 = pat
mt+1 = qat
at+1 = mt + (1-p-q)at
WRITE OUT A MATRIX, A, if this is written as a dynamical system, vt+1 = AVt
Ft+1 = pat: This equation states that the number of failed components in the coming month (t + 1, meaning the month after the current month), can be represented as the number of active components during the current month, multiplied by the fraction of components that fail in the proceeding month (t+1); or ANY month, t.
i.e.
if there are 12 active components during the second month (at = 12). And 25% of those fail by the end of the month (p = 0.25). The number of failed components in the third month is 12*0.25 = 3. Hence ft+1 = 3 (the number of failed components in the coming month).
mt+1 = qat: This equation states that the number of components under maintenance in the coming months (t + 1), can be represented as the number of failed components in the current month, added to the fraction of components removed for maintenance (q) multiplied by the number of active components (at) in the current month.
I.e.
The number of components under maintenance in the UPCOMING month will be the number of failed components by the end of the CURRENT month, ft + the fraction that have been REMOVED for maintenance, qat in the CURRENT month, giving the total number of components needing repair AND under repair FOR THE UPCOMING MONTH.
at+1 = mt + (1-p-q)at : this equation states that the number of active components in the up coming months, (t+1) is equivalent to the number of components under maintenance in the current month (since these will be available for use during the proceeding month), in addition to 1 subtract the percent that fail in the current month, and subtract the fraction taken off-line for maintenance in the current month multiplied by all active components, at; yielding the available active components for use during the proceeding month!
Now for the juicy stublack
It is stated that Vt = [ft, mt, at]T , which represents the state vector at the end of the month, t. We can assume that during the very first month, all units are functional, and hence, initially, ft = 0, mt = 0 and at = 13200.
We are given the individual components of the state vector at any month with the equations above.
We can use this to form a matrix which represents the state vector at any month, Vt+1.
\begin{bmatrix}
&p &q &(1-p-q) \\
&1 &0 &0 \\
&1 &1 &0 \\
&1 &1 &1
\end{bmatrix}\begin{bmatrix}
&vt \\
&0\\
&0\\
&13,200
\end{bmatrix}
(not sure how to make matrices side by side, so please pretend that these two are being multiplied)
am I doing this right o____o
it looks a bit wrong,
Q
A system has a “steady state” vector if there is a state vector v*
that never changes over time, so that Av* = v*
What eigenvalue must the matrix possesses if there is
to be a steady state? Show this is an eigenvalue of matrix A for any value of p
and q , so that a steady state must always exist for this system
I have no idea how to approach this part =[
PLEASE HELP MEEEE =)
<3 <3
also, for the second question, if I take the determinant of the matrix i obtained, it is evident that λ = 1 is the eigenvalue (just looking at the matrix)
..so I'm really confused if I'm even on the right track. this seems like it would be too easy.
Ft+1 = pat
mt+1 = qat
i.e.
I.e.
\begin{bmatrix}
&p &q &(1-p-q) \\
&1 &0 &0 \\
&1 &1 &0 \\
&1 &1 &1
&vt \\
&0\\
&0\\
&13,200
\end{bmatrix}
Q
<3 <3
The easiest approach is to recognize that you have a Markov chain with N states, where N = 13,200*13,201/2; we can identify the states as pairs (i,j), where i+j <= 13,200; here i = f, j = m (and a = 13,200-i-j). If we write out all the pairs in a line we get an N-dimensional state probability vector and an NxN 1-step transition probability matrix. Of course, the matrix is huge but sparse, with most of its elements = 0.
To tell whether there is a limiting distribution (there is always a steady-state, but not always a limiting distribution), you can try to see if all states are interconnected, and if at least one state is aperiodic. If so, there will be a limiting distribution for any 0 < p,q < 1. (I would think of p and q as probabilities, not fractions.)
RGV
can you pretty please elaborate a little bit more, I do not understand what you are saying.
from what you've said I understand the following
1) f + m < 32000
2) a = 32000 - f - m
I went and youtubed markov to try and understand more what you are saying and got the following
Initially, V(t) = [0, 0, 32000]T (something we had known already)
I am going to search more on youtube on markov and see if I can get something,
hopefully you are still online in an hour or two (please be online =[, this projects due tomorrow)
1) f + m < 32000
Forget my previous post---it was for a different problem. For the problem exactly as you have described it I get a slightly different set of dynamical equations. In particular, I get an equation for m(t+1) that involves both f(t) and a(t), unlike yours.
RGV
  • · Replies 27 ·
  • · Replies 27 ·
