Matrix formulation of an operator
34 replies · 4K views · last reply
tanaygupta2000
Consider an N-dimensional linear vector space spanned by the ortho-normal basis
states, {|b1>, |b2>, ...., |bN>}. An operator R is given to operate on these basis stats as: R|b(j) = |b(j+1)> for j=1 to (N-1), and R|bN> = |b1>.
Write R in the matrix form in the given basis.
<ψ|R|ψ> = Σ(i) Σ(j) <ψ|bj> <bj|R|bi> <bi|ψ>
where
R operator = <bj|R|bi> matrix
Handwritten notes deriving the matrix of an operator R in the basis b1 to bN, with a final matrix of zeros and ones whose ones lie on the subdivided diagonal below the main diagonal.
I have successfully found the N by N matrix corresponding to the operator R.
But the problem is, whenever I try to operate R on |bj> basis vectors, I am not getting |b(j+1)> as it should be.
Instead, I am getting result as given in the question only by <bj|R = <b(j+1)|
Matrix is not working with kets.
Please help !
tanaygupta2000 said:
Homework Statement:: Consider an N-dimensional linear vector space spanned by the ortho-normal basis
states, {|b1>, |b2>, ..., |bN>}. An operator R is given to operate on these basis stats as: R|b(j) = |b(j+1)> for j=1 to (N-1), and R|bN> = |b1>.
Relevant Equations:: <ψ|R|ψ> = Σ(i) Σ(j) <ψ|bj> <bj|R|bi> <bi|ψ>
where
Please help !
The matrix looks right to me. What do you get for ##R|b_1 \rangle##?
It is behaving like R|b(j) = |b(j-1)> instead of R|b(j) = |b(j+1)>
The question was what is ##R|b_1 \rangle##?
It is |bN>
Handwritten derivation: R|b1> equals an N by N cyclic shift matrix times a column vector of components b1 to bN, giving a column with bN, b1, b2 up to bN-1, then lines stating R|b1> = |bN> should be |b2>, R|b2> = |b1> should be |b3>, R|b3> = |b2> should be |b4>, down to R|bN> = |bN-1> should be |bN>.
  • Handwritten derivation: R|b1> equals an N by N matrix with ones on the subdiagonal and a one in the top-right corner, times the column vector of b1 to bN, giving the column (bN, b1, b2, ..., bN-1). Below, R|b1> = |bN> should be |b2>, R|b2> = |b1> should be |b3>, R|b3> = |b2> should be |b4>, and R|bN> = |bN-1> should be |b1>.
PeroK said:
Hmm! $$|b_1 \rangle = (1, 0, \dots 0)^T$$
But then R|b1> will be zero?
Because R11 is zero
PeroK said:
Try with ##N = 3##.
For N=2, R = [0, 0 first row and 1, 0 second row]
Is it right?
Is it right?
Try ##N = 3## instead.
For N=3, R = [0, 0, 0; 1, 0, 0; 0, 1, 0]
R|b1> is still 0
since first row is zero
R|b1> is still 0
Well, no. ##R## has a ##1## at the end of the first row.
Sir the end has <b1|b4>
How it can be 1?
How it can be 1?
There is no ##b_4## if ##N = 3##.
How it can be 1?
In accordance with <b1|R|b3>
So what will be <b1|R|b3>?
I am getting confused
I can see that. From your post #5, we have:
$$R(N=3) = [0, 0, 1; 1, 0, 0; 0, 1, 0]$$
Sir are the last entries of rows II and III belong from the last column of R(N, N)?
If ##N = 3##, then the ##1## at the end is in the 3rd column. ##N## is a variable in this case.
Thank You so much !
Okay, but note that I've spotted an error now.
Yes sir my mistake it should be 0, 0, 1, 0
That's right now.
PeroK said:
No. It will be ##b_2##.
Sir please assist me where am I doing mistake.
Handwritten notes: For N=3, a 3x3 matrix R with rows (0 0 1), (1 0 0), (0 1 0), checked. Column vectors |b1> = (1,0,0), |b2> = (0,1,0), |b3> = (0,0,1). R|b1> is computed as (0,0,0), marked not equal to |b2>.
In Shankar it is given like this:
Textbook example 1.6.1 showing R(πi/2) acting on basis kets: R|1> = |1>, R|2> = |3>, R|3> = -|2>, followed by the 3x3 matrix representation with rows (1 0 0), (0 0 -1), (0 1 0) labeled (1.6.4).
But I'm having trouble verifying it mathematically as given in the question.
I just tried using a hermitian of R since it is behaving like a rotation matrix and I got ... is this good?
Handwritten derivation: R† (3x3) times ket |b> equals the conjugate transpose of the 3x3 matrix [0 0 1; 1 0 0; 0 1 0] applied to column vector (b1, b2, b3), giving [0 1 0; 0 0 1; 1 0 0] times the vector, then the column (b2, b3, b1).
