Matrix Proofs Homework: Q1 & Q2
  • Thread starter Thread starter colt
    Matrix Proofs
9 replies · 2K views
colt
First Question: Be A and B square matrix. Show that if A and B are invertible matrix, then: (A + B)^(-1) = A^(-1) * [I + B*A^(-1)]^(-1)
First Queston: (A+B)^(-1) = [A^(-1) + A^(-1)*B*A^(-1)]^(-1) (I distributed the a^(-1) outside the []). Then I don't know what else I can do
Second Question: Be A and P matrix of nxn dimension with P being invertible. So det (P^(-1)*A*P) = det(A)
I would like to transform the (P^(-1)*A*P) into (I*A), but since matrix multiplication ain't commutative, I don't know how to get there
You can verify this by showing that
$$(A+B)(A^{-1}[I + BA^{-1}]^{-1}) = I$$
What properties of determinants do you know about?
I was only able to develop it until here:
[itex]A(A^{-1}[I + BA^{-1}]^{-1}) + B(A^{-1}[I + BA^{-1}]^{-1}) =[/itex]
[itex]AA^{-1}[I + BA^{-1}]^{-}) + BA^{-1}[I + BA^{-1}]^{-1} =[/itex]
[itex]I[I + BA^{-1}]^{-1} + BA^{-1}[I + BA^{-1}]^{-1} =[/itex]
[itex][I + BA^{-1}]^{-1} + B[A^{-1} + A^{-1}BA^{-1}]^{-1} =[/itex]
I know that de determinant of A^(-1) = 1/ det A, that det A = det A transpose, that the det A with a constant K that multiplies one of its lines is equal to K that multiplies det A and so that if this constant multiplies all lines. then det A = K^n * det A
I think the problem is asking you to assume that the wrong things are invertible. A and B invertible doesn't show A+B is invertible. You need to assume that everything is invertible. Then for the first use that C^(-1)D^(-1)=(DC)^(-1). Figure out what to put D and C equal to.
Now try using the distributive property.
Another important property: ##\det(AB) = \det(A)\det(B)##. Do you know this one? If so, the second problem should be easy.
How? The identity is irrelevant, so only the [itex]a^{-1}[/itex] is left, and I already distributed it without seeing any meaningful result
Another important property:[itex]det(AB)=det(A)det(B).[/itex] Do you know this one? If so, the second problem should be easy.
Ah yes, had forgotten this one.
Didn't really understand. Can you try to explain it once more?
What I mean is take the inverse of both sides of (A + B)^(-1) = A^(-1) * [I + B*A^(-1)]^(-1). What you first did, distributing the A^(-1) inside of the [] is quite wrong. There's a ^(-1) on the bracket.
jbunniii said:
now try using the distributive property.
colt said:
how? The identity is irrelevant, so only the [itex]a^{-1}[/itex] is left, and i already distributed it without seeing any meaningful result
Both terms have a common factor on the right, namely ##(I + BA^{-1})^{-1}##:
$$I(I+BA^{-1})^{-1} + BA^{-1}(I+BA^{-1})^{-1}$$
So factor out that common term and see what you get.
Yes, I have to admit that I was suspicious about this distributive. Thanks for pointing it out.
Both terms have a common factor on the right, namely (I+BA−1)−1:
[itex]I(I+BA−1)−1+BA−1(I+BA−1)−1[/itex]
I see it now. Thanks
