Matrix Question: A*B=A (B is non-identity)
  • Context: Graduate
  • Thread starter Thread starter thinktank2
    Matrix
The discussion revolves around the relationship between two non-identity matrices A and B, specifically under the condition that A * B = A. Participants explore the implications of this equation, potential methods for finding matrix A given matrix B, and connections to eigenvalues and eigenvectors.
  • Homework-related
  • One participant questions if there is a specific name for the relationship between matrices A and B when A * B = A.
  • Another participant suggests that the problem may relate to eigenvalues and eigenvectors, hinting at a deeper mathematical connection.
  • A participant notes that if a matrix A exists for a given B, then any scalar multiple of A (k*A) will also satisfy the equation A * B = A, indicating the existence of infinite solutions for B.
  • One participant proposes transforming the equation A * B = A into AB = B by taking the transpose of both sides, suggesting this may simplify the problem.
  • It is mentioned that other than the trivial solution A=0, there are no solutions if one is not an eigenvalue of B.
Participants express uncertainty and explore various hints and approaches without reaching a consensus on a definitive method for finding matrix A given B. Multiple perspectives on the relationship between A and B are presented, indicating ongoing debate.
Participants acknowledge the complexity of the problem and the potential for missing assumptions or definitions related to eigenvalues and eigenvectors.
thinktank2
If two ℝeal valued, non-identity matrices A (dimension MxN) and B (dimension NxN)
satisfy the condition A * B = A
Is there a name for the relationship between B and A ?
For example for: [itex]A = <br /> \left( \begin{array}{cc}<br /> \frac{1}{3} & \frac{2}{3} \end{array} \right), \quad B = \left( \begin{array}{cc}<br /> \frac{3}{5} & \frac{2}{5} \\<br /> \frac{1}{5} & \frac{4}{5} \end{array} \right) \quad A * B = \left( \begin{array}{cc}<br /> \frac{1}{3} & \frac{2}{3} \end{array} \right)[/itex]
My Observations:
  • If such A exists for B, then for any real number k, k*A is also a solution for B
    since (k*A)*B = k*(A*B)=k*A
    implies, there will be infinite solutions for B.
  • [itex] p\to+\infty{\left( \begin{array}{cc}<br /> \frac{3}{5} & \frac{2}{5} \\<br /> \frac{1}{5} & \frac{4}{5} \end{array} \right)}^p = \left( \begin{array}{cc}<br /> \frac{1}{3} & \frac{2}{3} \\<br /> \frac{1}{3} & \frac{2}{3} \end{array} \right)[/itex]
My Question: Given a matrix B, how do we find A such that A*B=A ?
This looks a bit too much like homework for me to give a direct answer (now).
I can give a hint in the form of a question: How is this related to eigenvalues and eigenvectors?
Thank you very much for the hint. I swear this not my homework. I know I missed something very basic but didn't know which one.
I am hitting a wall. May I request another hint or two?
D_H gave a pretty good hint. I'll give you a little more.
First consider the problem AB=B. Given A you can easily find all such B using eigenthings.
You can transform AB=A into this form by taking the transpose of both sides.
Very good problem if you came up with it yourself.
And one more hint: Other than the trivial solution A=0, there are no solutions if one is not an eigenvalue of B.
  • · Replies 19 ·
