Max and Min Forces for Non-Slip Block on Inclined Wedge
  • Thread starter Thread starter bassplayer142
    Force Newton
The problem involves a block resting on an inclined wedge, with a focus on determining the maximum and minimum forces required to prevent slipping. The context includes concepts of static friction, forces acting on the block and wedge, and the relationship between their accelerations.
  • Participants discuss setting up equations of motion for both the block and the wedge, analyzing forces, and considering the effects of acceleration. Questions arise regarding the relationship between the accelerations of the block and the wedge, as well as the implications of the block not slipping.
There is an ongoing exploration of the forces acting on the block and wedge, with some participants providing hints and guidance on how to approach the problem. Multiple interpretations of the setup and the forces involved are being discussed, but no consensus has been reached.
Participants are navigating the complexities of the problem, including the effects of the wedge's acceleration and the conditions for static friction. There is an acknowledgment of the need to analyze the system from an inertial frame rather than the wedge's perspective.
bassplayer142
A block of Mass 0.5Kg rests on the inclined surface of a wedge of mass 2Kg. The wedge is acted on by a horizontal force that slides on a frictionless surface.
note that the force is towards the box on the incline and not away from it.
a) If the coefficient of static friction between the wedge and the block is u=0.8 and the angle of the incline is 35 degrees, find the maximum and minimum values for F for which the block does not slip.
I set up the i and j vectors for the block and the ramp. I solved the general equations of friction between the two. Not sure what to do from there.
Both these questions have been eating away at me today.
Show exactly what you did.
I would start by analyzing the forces acting on the block. Hint: Try to find the acceleration of block.
Mass 1:
i = m1*g*sin theta - (F-friction)=m1*a
j = (F-normal) - m1*g*cos Theta = 0
mass 2
F = m2*a
j = (F-normal)-m1*g - m2*g = 0
I then solved for the general equation of F-normal and pluged in u to get the friction equations.
I don't know where to go next. Does the force in F=ma the same force that will be exerted in the negative x direction>?
thanks
Several problems here:
bassplayer142 said:
Mass 1:
Seems like you are trying to treat the block as if it were accelerating down the wedge--but it's not sliding down the wedge. Further, you are trying to measure acceleration of the block with respect to the wedge, but the wedge itself is accelerating.
mass 2
F = m2*a
How does the acceleration of the wedge relate to the acceleration of the block?
Answer this question: Since the block is not sliding down the wedge, what direction must the wedge and ramp be accelerating?
Hint: Stick to analyzing the forces on the block as viewed in the inertial frame of the floor. (Instead of using coordinates parallel and perpendicular to the wedge surface, use horizontal and vertical.)
Are you saying that the block should be accelerating along the horizon at the same magnitude as the ramp?
thanks
Yes. The block is not slipping down the ramp, so they must move together.
a=F/(m+M) towards Earth for m+M
Thanks a lot you guys. I understand it now.
you are welcome:smile:
  • · Replies 19 ·
