Max angle of deflection in a relativistic elastic collision
The discussion revolves around a relativistic elastic collision problem, focusing on determining the maximum angle of deflection. Participants are analyzing the conservation of linear momentum and energy, as well as the energy-momentum relationship in the context of relativistic physics.
  • Mixed
  • Participants explore various equations related to momentum and energy, questioning the validity of certain equations and assumptions made in the problem. There are attempts to derive expressions for the angle of deflection and to resolve variables such as the Lorentz factor and velocities in different frames.
The discussion is active, with participants providing feedback on each other's equations and reasoning. Some express agreement on the potential inaccuracies in the problem statement, while others suggest alternative approaches to simplify the calculations. There is no explicit consensus on the correct method or final answer yet.
Participants note that the problem may have constraints, such as the assumption of elastic collisions and the requirement to avoid certain advanced concepts like 4-vectors. Additionally, the original poster mentions that the problem is from a textbook, which may influence the expectations for the solution.
redoopi
Conservation of linear momentum
Conservation of energy
Energy-momentum relationship: ##E^2-(m_0c^2)^2=c^2p^2##
Lorentz transformation of energy: ##p=\gamma(v)(p'+vE'/c^2)##
##\mathbf{p}=\gamma(v)m_0v##, ##E=\gamma(v)m_0c^2##
My attempt to the first question:
In laboratory frame ##S##:
In a zero-momentum frame ##S'## moving with velocity ##v## relative to ##S##:
Components of ##p_3'## are:
$$ p_{3x}'=p_3'\cos\theta' \tag{1} $$
$$ p_{3y}'=p_3'\sin\theta' \tag{2} $$
By Lorentz transformations for energy and momentum,
$$ p_{3x}=\gamma(v)(p_{3x}'+vE_3'/c^2) \tag{3} $$
$$ p_{3y}=p_{3y}' \tag{4} $$
Since
$$ E_3'=\gamma(v_3')Mc^2 \tag{5} $$
$$ p_3'=\gamma(v_3')Mv_3' \tag{6} $$
Substitute (6) into (5),
$$ E_3'=p_3'c^2/v_3' \tag{7} $$
Substitute (1) and (7) into (3),
$$ p_{3x}=\gamma(v)p_3'(\cos\theta'+v/v_3') \tag{8} $$
Substitute (2) into (4),
$$ p_{3y}=p_3'\sin\theta' \tag{9} $$
So the angle of deflection of mass $M$ is given by
$$ \tan\theta=\frac{p_{3y}}{p_{3x}}=\frac{\sin\theta'}{\gamma(v)(\cos\theta'+v/v_3')} \tag{10} $$
If we can resolve ##\gamma(v)## and ##v_3'##, then we can take the derivative of ##\tan\theta## with respect to ##\theta'## and obtain its maximum value.
But I am facing two difficulties:
(1) How to obtain ##\gamma(v)##? My attempt:
$$ v_2'=-v \tag{11} $$
$$ v_1'=v_1-v \tag{12} $$
$$ \gamma(v_1)=M/m \tag{13} \quad \text{(given in the question)} $$
$$ \gamma(v_2')=\gamma(-v)=\gamma(v) \tag{14} $$
Since $S'$ is a zero-momentum frame,
$$ \gamma(v_1')Mv_1'=\gamma(v_2')mv_2' \tag{15} $$
Substitute (11) - (14) into (15),
$$ \gamma(v_1-v)M(v_1-v)=-\gamma(v)mv \tag{16} $$
Now we can solve for ##v## and then calculate ##\gamma(v)##, but the calculation is very complicated.
(2) How to obtain ##v_3'##? Apply energy-momentum relationship on mass ##M## in ##S'## after collision:
$$ (E_3')^2-(Mc^2)^2=(cp_3')^2 \tag{17} $$
Now we have equation (7) and (17) for the three variables ##E_3'##, ##p_3'## and ##v_3'##. We need one more relationship to solve for ##v_3'##.
Besides, it will take too much effort to solve the above equations. I guess there should be a simpler approach. Do you have any idea?
Note 1 : The author only briefly mentioned 4-vectors, so we are not supposed to use it to solve this problem.
Note 2: Another approach is as follows:
$$ \mathbf{p}_1=\mathbf{p}_3+\mathbf{p}_4 \tag{18} $$
$$ E_1+mc^2=E_3+E_4 \tag{19} $$
$$ E_1=\gamma(v_1)Mc^2 \tag{20} $$
$$ E_1^2-(Mc^2)^2=c^2p_1^2 \tag{21} $$
$$ E_3^2-(Mc^2)^2=c^2p_3^2 \tag{22} $$
$$ E_4^2-(mc^2)^2=c^2p_4^2 \tag{23} $$
By (18),
$$ (\mathbf{p}_1-\mathbf{p}_3)\cdot(\mathbf{p}_1-\mathbf{p}_3)=\mathbf{p}_4\cdot\mathbf{p}_4 \tag{24} $$
$$ p_1^2-2p_1p_3\cos\theta+p_3^2=p_4^2 \tag{25} $$
Substitute (13) and (19) - (23) into (25), take derivative of ##\cos\theta## with respect to ##p_3##, set it to zero, then we can find the value of ##p_3## that gives the maximum value of ##\theta##. But the computation is very complicated.
Note 3: A general expression for ##\theta## can be found on p.309 of Goldstein's Classical Mechanics. It seems that the answer in the question is incorrect.
Equation (17) is wrong. Equation (12) is wrong. I don’t see the point of (7) because
if you think combining 7 and (the corrected) 17 will lead to anything but a trivial identity... then I disagree.
This is what happens when you work with every variable: you get lost in blind alleys. You only need two of {mass, energy, momentum, speed, gamma-factor} to determine all the others; try not lose sight of the physics amongst the identities.
redoopi said:
(1) How to obtain γ(v)?
You defined v to be the velocity of the center of mass. How would you find that classically?I have a question (for anybody) about this question. “Elastic collision” only implies the sum of the masses is conserved. Is there any reason to assume each mass is individually conserved (other than to make the problem solvable)?
@redoopi I agree that the answer as given in the statement of the problem is incorrect. I believe the answer is ##\theta_{max} = \sin^{-1}\frac{m}{M}## for any initial speed of ##M## (as long as ##M > m##).
So, for ##M \gg m##, ##\theta_{max} \approx \frac{m}{M}##
Your method outlined at the end of your post (Note 2) will work. I don't see a way to avoid the tedious calculation. It took me about 2 pages of algebra. If you want to try working it through, here are some intermediate expressions that I found (with ##c = 1##): $$\cos \theta = \frac{E_3 \left( E_1+m \right) - E_1 m - M^2}{p_1 p_3}$$
##\theta_{max}## occurs when $$E_3 = \frac{M^2(E_1+m)}{M^2 + E_1m}$$ The corresponding value of ##p_3## is
$$p_3 = \frac{p_1 M \sqrt{ M^2-m^2 }}{M^2+E_1m} $$
Is this a problem from a textbook? If so, can you tell us which textbook?
Equation (12) (and hence (16)) is wrong, I should have used relativistic velocity addition (I found it difficult to get out of the habit of using Galilean velocity addition).
But why is equation (17) wrong? The rest energy (##Mc^2##) is an energy-momentum invariant, i.e. ##(E^2)-(cp)^2=(E'^2)-(cp')^2=(Mc^2)^2##.
Equation (7) and (17) contain three variables (##E_3',p_3',v_3'##). So we still need one more equation to solve them.
I didn't assume each mass is individually conserved. ##M## and ##m## represent the rest masses. The relativistic masses are ##\gamma M## and ##\gamma m##.
The textbook is "Special Relativity" by A.P. French.
I finally took the time to do the calculations. Surprisingly it is not as tedious as I thought. Here are my calculations:
\begin{align}
p_1^2 &= (\gamma^2-1)M^2c^2 \\
p_1 &= \sqrt{(\gamma^2-1)}Mc \\
E_4=E_1+mc^2-E_3 &= \gamma Mc^2+mc^2-\sqrt{c^2p_3^2+M^2c^4} \\
&=(\gamma M+m)c^2-c\sqrt{p_3^2+M^2c^2} \\
E_4^2 &= (\gamma M+m)^2c^4-2(\gamma M+m)c^3\sqrt{p_3^2+M^2c^2}+p_3^2c^2+M^2c^4 \\
&= (\gamma^2+1)M^2c^4+2\gamma Mmc^4+m^2c^4-2(\gamma M+m)c^3\sqrt{p_3^2+M^2c^2}+p_3^2c^2 \\
p_4^2 &= (\gamma^2+1)M^2c^2+2\gamma Mmc^2-2(\gamma M+m)c\sqrt{p_3^2+M^2c^2}+p_3^2 \\
(\gamma^2-1)M^2c^2-2\sqrt{(\gamma^2-1)}Mcp_3\cos\theta &= (\gamma^2+1)M^2c^2+2\gamma Mmc^2-2(\gamma M+m)c\sqrt{p_3^2+M^2c^2} \\
2\sqrt{(\gamma^2-1)}Mcp_3\cos\theta &= -2M^2c^2-2\gamma Mmc^2+2(\gamma M+m)c\sqrt{p_3^2+M^2c^2} \\
\cos\theta &= \frac{(\gamma M+m)\sqrt{p_3^2+M^2c^2}-M^2c-\gamma Mmc}{\sqrt{(\gamma^2-1)}Mp_3}
\end{align}
Then I use Wolfram Alpha to solve ##d(cos\theta)/dp_3=0## for ##p_3##:
solve d/dp (((g*M+m) sqrt(p^2+M^2*c^2)-M^2*c-g*M*m*c)/(sqrt(g^2-1)*M*p)) = 0 for p
\begin{align}
p_3 &= \frac{Mc\sqrt{\gamma^2-1}\sqrt{M^2-m^2}}{\gamma m+M}
\end{align}
Take ##\gamma=M/m##, we have
\begin{align}
p_3 &= \frac{(M^2-m^2)c}{2m}\approx \frac{M^2c}{2m} \\\\
\cos\theta_{max} &\approx \frac{(M^2+m^2)\sqrt{M^2+4m^2}-4Mm^2}{M^2\sqrt{M^2-m^2}} \\
&\approx 1-2\left(\frac{\sqrt{2}m}{M}\right)^2
\end{align}
Since ##\cos x=1-2\sin^2 (x/2)##, we have
\begin{align}
\sin\frac{\theta_{max}}{2} &\approx \frac{\sqrt{2}m}{M}
\end{align}
Therefore,
\begin{align}
\theta_{max} &\approx \frac{2\sqrt{2}m}{M}
\end{align}
Yes, that is correct. In your OP you mixed the mass and momentum terms.
I guess you can say that... In my eyes those 3 variables represent one unknown with zero equations. 7 and 17 are just identities which combine to give more identities.
You did assume that (I believe you have to). When I say mass I mean rest mass. “Elastic collision” means kinetic energy is conserved, which then implies rest energy is conserved, which means that the total (rest) mass is conserved before and after the collision. What I’m wondering is how we known each mass is unchanged. If we had m → m+k and M → M-k it would still be elastic.
That's a well-known, standard text. But I still think that his answer with the ##\sqrt{3}## is wrong.
$$\cos\theta = \frac{(\gamma M+m)\sqrt{p_3^2+M^2c^2}-M^2c-\gamma Mmc}{\sqrt{(\gamma^2-1)}Mp_3}$$
$$p_3 = \frac{Mc\sqrt{\gamma^2-1}\sqrt{M^2-m^2}}{\gamma m+M}$$
OK, these appear to agree with the expressions I listed in my previous post.
$$p_3 = \frac{(M^2-m^2)c}{2m}\approx \frac{M^2c}{2m} $$
This is too severe of an approximation if you want your result for ##\cos \theta_{max}## to be accurate to order ##\frac{m^2}{M^2}##. Note that you can write
$$p_3 = \frac{(M^2-m^2)c}{2m} = \frac{M^2c}{2m} \left( 1 - \frac{m^2}{M^2} \right)$$ and you need to keep the factor ##\left( 1 - \frac{m^2}{M^2} \right)##.
By substituting the above expression for ##p_3## and ##\gamma=M/m## into the expression for ##\cos\theta## (equation (10)), we can obtain
$$\cos\theta_{max}=\sqrt{1-\left(\frac{m}{M}\right)^2}$$
and hence ##\sin\theta_{max}=m/M##.
Looks good. You can show that this result for ##\sin \theta_{max}## does not depend on assuming ##\gamma = \frac{M}{m}##. The only condition is that ##M >m##.
I don't get it. ##(E_3')^2-(Mc^2)^2=(cp_3')^2## is exactly the form of ##(E'^2)-(cp')^2=(Mc^2)^2##.
You may read p.169-172 of "Special Relativity" by A.P. French. The idea is like this: In Newtonian mechanics, we know by experiments that a specific type of collisions can be described by the equation ##\alpha_1\mathbf{u}_1+\alpha_2\mathbf{u}_2=\alpha_1\mathbf{v}_1+\alpha_2\mathbf{v}_2##, where the scalars ##\alpha_1## and ##\alpha_2## are intrinsic properties of object 1 and 2. We call that property inertial mass, and we have conservation of linear momentum. We also found that in this case kinetic energy is conserved, and we call this type of collision "perfectly elastic". Now in relativistic mechanics, this simple equation no longer holds. But if we assert conservation of linear momentum, then we must re-define inertial mass (##\alpha_i##) to be ##\gamma## times the inertial mass in Newtonian mechanics (which we now called the rest mass, and is a constant in the equation). So it is experimental facts + definition.
Note: By Keppler 2nd Ed. p.479, the term "mass" refers to relativisitc mass. If you mean "rest mass", you should state it explicitly.
After all that I'm wondering if this is any different from the result you would obtain in a classical (ie non relativistic) collision for which m << M ?
Good observation. The relativistic result for ##\theta_{max}## does not depend on the initial speed of ##M## when ##m \ll M##. So, the relativistic result for ##\theta_{max}## matches the classical result when ##m \ll M##.
In principle, should it be possible to find an exact expression for maximum angle of deflection for ANY mass M colliding with stationary mass m given just M > m. [so no approximations such as M +- m ≅ M, or sin(m/M) ≅ m/M ] ? For M = m I think the answer is π/2.
Yes. For any ##M>m## and for any initial speed of ##M## the result is ##\sin \theta_{max} = m/M##. So, this agrees with the classical result. Also, as you noted, ##\theta_{max} = \pi /2## for ##M = m##.
If ##M \gg m##, then of course you can further simplify to ##\theta_{max} \approx m/M##.
For maximum deflection, the angle between original line of motion (of larger mass) and trajectory of the smaller mass (after collision) given by acos(m/M)/2. Alternatively 180 - (same angle) for angle between original line of motion and line of centres during collision. Does that seem right? Thus far it's an empirical result.
  • · Replies 18 ·
  • · Replies 59 ·
