Max Height: Solving Displacement Problems
  • Thread starter Thread starter cyspope
    Displacement
5 replies · 5K views
cyspope
A rocket starts from rest and accelerates for 3.50 s with an acceleration of 5.00 m/s². If it continues to rise until its velocity is zero, what will be its maximum height?
I thought I had to use the "UNIFORM MOTION with CONSTANT ACCELERATION" formula, which is d=vi*t+(1/2)*a*t²
d = distance
vi = initial velocity
t = time
a = acceleration
d = 0*3.5+(1/2)(5.00 m/s²)(3.5)²
I am not sure whether I set up the problem correctly or not.
hey cyspope,
what's the velocity of the rocket after 3.50 s? use this velocity* to determine the extra displacement, [this will be the initial velocity vo], you may use the velocity & displacement equation.
* note the rocket will be decelerating under the effect of g = 9.8 m/s2 till the velocity reaches zero.
drizzle said:
hey cyspope,
It doesn't says about the velocity of the rocket after 3.50 s. and How would you apply the gravity, which is 9.8 m/s² into the equation?
hint:
cyspope said:
A rocket starts from rest and accelerates for 3.50 s with an acceleration of 5.00 m/s²...
don't forget, there're two different displacements, d1 [which you can calculate using the first part of the question], and d2 [as described above]. the maximum displacement [height] is then d1+d2
Is the answer 63.125 m?
