Max Height: Solving Displacement Problems
  • Thread starter Thread starter cyspope
    Displacement
cyspope
A rocket starts from rest and accelerates for 3.50 s with an acceleration of 5.00 m/s². If it continues to rise until its velocity is zero, what will be its maximum height?
I thought I had to use the "UNIFORM MOTION with CONSTANT ACCELERATION" formula, which is d=vi*t+(1/2)*a*t²
d = distance
vi = initial velocity
t = time
a = acceleration
d = 0*3.5+(1/2)(5.00 m/s²)(3.5)²
I am not sure whether I set up the problem correctly or not.
hey cyspope,
what's the velocity of the rocket after 3.50 s? use this velocity* to determine the extra displacement, [this will be the initial velocity vo], you may use the velocity & displacement equation.
* note the rocket will be decelerating under the effect of g = 9.8 m/s2 till the velocity reaches zero.
drizzle said:
hey cyspope,
It doesn't says about the velocity of the rocket after 3.50 s. and How would you apply the gravity, which is 9.8 m/s² into the equation?
hint:
cyspope said:
A rocket starts from rest and accelerates for 3.50 s with an acceleration of 5.00 m/s²...
don't forget, there're two different displacements, d1 [which you can calculate using the first part of the question], and d2 [as described above]. the maximum displacement [height] is then d1+d2
Is the answer 63.125 m?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
