Maxima/Minima of extrema function f(x,y)=x
  • Thread starter Thread starter RyanV
    Extrema Function
The discussion focuses on finding the extrema of the function f(x, y) = x under the constraint x² + 2y² = 3. The critical points identified are (\sqrt{3}, 0) and (-\sqrt{3}, 0). However, the determinant (det) calculated using the second derivative test results in det = 0, leading to an inconclusive outcome. The book suggests that (\sqrt{3}, 0) is a maximum and (-\sqrt{3}, 0) is a minimum, highlighting a misunderstanding of the function's behavior as a plane with no curvature.
  • Understanding of multivariable calculus, specifically extrema finding techniques.
  • Familiarity with the method of Lagrange multipliers for constrained optimization.
  • Knowledge of second derivative tests for classifying critical points.
  • Ability to compute partial derivatives and evaluate limits.
  • Study the method of Lagrange multipliers for optimization under constraints.
  • Learn about the implications of the determinant in the second derivative test for multivariable functions.
  • Explore graphical representations of functions to better understand their behavior.
  • Investigate the classification of critical points in multivariable calculus.
Students and educators in multivariable calculus, mathematicians focusing on optimization problems, and anyone seeking to deepen their understanding of extrema in constrained environments.
RyanV
Find the extrema of the function subject to the given constraint.
f (x, y) = x
x2 + 2y2 = 3
det = fxx * fyy - (fxy)2
If det > 0,
fxx < 0 \Rightarrow MAXIMUM
fxx > 0 \Rightarrow MINIMUM
If det < 0,
\Rightarrow SADDLE POINT
If det = 0m
Inconclusive
I appear to be struggling with this maxima/minima stuff. Previous questions were just correct. I had to look at the book's answers to figure a way there. I seem to be missing something...but here is my attempt:
Since x2 + 2y2 = 3,
x = \pm\sqrt{3 - 2y<sup>2</sup>}
Therefore,
f(x, y) = \pm\sqrt{3 - 2y<sup>2</sup>}
At critical point,
\nabla f = (0, - \frac{2y}{\sqrt{3 - 2y<sup>2</sup>}} )
= (0, 0)
Therefore, equating gives
0 = 0
- \frac{2y}{\sqrt{3 - 2y<sup>2</sup>}} = 0
So extrema points at (\sqrt{3}, 0) & (-\sqrt{3}, 0) since y = 0.
To find max/min/saddle, find det.
fxx = 0
fxy = 0
det = 0 * fyy - (0)2
det = 0
Which is inconclusive. The book has (\sqrt{3}, 0) as a maximum and (-\sqrt{3}, 0) as a minimum.
I don't know what I'm missing out here...
Thanks in advance.
f (x, y) = x
x2 + 2y2 = 3
If det > 0,
If det < 0,
If det = 0m
Inconclusive
Since x2 + 2y2 = 3,
Tip: Don't mix [ sup] or [ sub] tags inside [ tex] tags. Instead use ^{} for exponents and _{} for subscripts.
RyanV said:
Therefore,
At critical point,
= (0, 0)
0 = 0
I don't see how the equation above is helpful at all.
fxx = 0
fxy = 0
det = 0
Thanks in advance.
What I think you are missing is some understanding of what f(x, y) = x looks like, which is a plane. Since a plane is a flat surface with no curvature, there are no dips or bumps. Also, since the domain of this plane is restricted to {(x, y) | x2 + 2y2 = 3}, any maximum or minimum points are attained at points the farthest away from the origin.
Ohh...I see... I feel so silly ><
Thanks a lot for that.
If I may, I have another question regarding maxima and minima...
Find local minima, maxima and saddle points of the function:
f(x, y) = (x2 + 3y2) e1-x2-y2
I started off finding the partial derivatives of x and y respectively and got:
fx = 2xe1-x2-y2 ( 1 - x2 - 3y2 )
fy = 2ye1-x2-y2 (3 - x2 - 3y2 )
At critical points, (fx, fy) = (0, 0)
Equating gives,
2xe1-x2-y2 ( 1 - x2 - 3y2 ) = 0 --- (1)
2ye1-x2-y2 (3 - x2 - 3y2 )= 0 --- (2)
After that I'm kinda lost...I slithered my way to get (0, 0) but very unconvincingly. I would rather have some solid reasoning as to why.
Like I mentioned earlier, I think I'm missing some understanding and maybe that's why I'm not getting this.
The answers give
Min at (0, 0),
max at (0, 1), (0, -1),
saddle at (-1, 0), (1, 0)
Thanks!
f(x, y) = (x2 + 3y2) e1-x2-y2I started off finding the partial derivatives of x and y respectively and got:
Equating gives,
The answers give
Min at (0, 0),
When you have a product equal to 0, then one of the factors must be equal to 0. For instance, from this equation
2xe^{1-x^2-y^2}(1-x^2-3y^2) = 0
you can conclude that x=0 or 1-x2-3y2=0. Similarly, the other equation gives you y=0 or 3-x2-3y2=0. Now you just have to find the solutions for all four possible combinations:
(1) x=0, y=0;
(2) x=0, 3-x2-3y2=0;
(3) y=0, 1-x2-3y2=0; and
(4) 1-x2-3y2=0, 3-x2-3y2=0.
Ooo, I see now. I think I managed to confuse myself by using how for eq (1),
since x = 0,
1-x2-3y2=0
1 - 3y2 = 0
which is definitely not looking good in terms of the answers. But I understand now =)
One last thing, so for the 4th solution: (4) 1-x2-3y2=0, 3-x2-3y2=0.
There isn't a solution for this yeah? Since all the variables x/y cancel out.
since x = 0,
1-x2-3y2=0
1 - 3y2 = 0
Right idea, but wrong equation. That's the one that has to hold if y is 0 and x isn't 0.
Yup, that combination has no solutions.
14K
