Maximizing Area: Solving an Inscribed Circle Problem in an Isosceles Triangle
  • Context: MHB
  • Thread starter Thread starter dexstarr
    Optimization
The discussion revolves around solving a problem related to finding the radius and area of the largest circle that can be inscribed in an isosceles triangle with two equal sides of length 1. Participants explore various mathematical approaches and reasoning related to the geometry of the triangle and the inscribed circle.
  • Homework-related
  • One participant expresses difficulty in combining the formulas for the area of a circle and a triangle to solve the problem.
  • Another participant suggests bisecting the triangle into two right triangles and using the two-intercept form of a line to express the hypotenuse, along with applying Pythagorean theorem.
  • A different participant proposes using Heron's Formula for the area of the triangle and suggests expressing the radius of the inscribed circle in terms of the third side of the triangle.
  • One participant presents a mathematical expression for the radius squared and discusses finding critical points to determine maximum values.
  • Another participant agrees with a previous calculation but admits to not fully understanding the steps taken to reach that conclusion.
  • Several participants request to see final answers or solutions to verify their own work, indicating a collaborative effort to check calculations.
There is no consensus on the final answer or method, as participants express differing levels of understanding and approach to the problem. Multiple competing views and methods remain present in the discussion.
Some participants reference specific mathematical steps and formulas, but there are unresolved assumptions and dependencies on definitions that may affect the conclusions drawn.
This discussion may be useful for students and enthusiasts of geometry, particularly those interested in inscribed figures and optimization problems within triangles.
dexstarr
Hey Everyone,
I'm having trouble setting up this word problem.
I know that area of a circle is pir2 and area of a triangle is 1/2bh but for some reason I can't find a way to combine these equation together.
What are the radius and area of the circle of maximum area that can be inscribed in an isosceles triangle whose two equal sides have length 1?
This is how I approached the problem:
Bisect the isosceles triangle into two right triangles, and put one of the right triangles in the $xy$-plane with the right angle at the origin, as in the diagram:
The vertical leg has length $b$ and the horizontal leg has length $b$.
The hypotenuse of the triangle lies along the line $y(x)$. By the two-intercept form of a line, we know:
$$\frac{x}{a}+\frac{y}{b}=1$$
By Pythagoras, and the fact that the hypotenuse is 1 unit in length, we know:
$$a^2+b^2=1$$
This will allow you to write the line in terms of one parameter.
Next, use the fact that the perpendicular distance from the point $(r,0)$ to this line is simply $r$. This will allow you to write $r$ as a function of one parameter. If you express the line in slope-intercept form, you may use the formula for the perpendicular distance between a point and a line:
$$d=\frac{\left|mx_0+b-y_0 \right|}{\sqrt{m^2+1}}$$
Once you have $r$ as a function of one parameter, differentiate $r$ with respect to this parameter, and equate to zero to find the critical value within the domain. Then evaluate $r$ at this critical value to find the maximum radius, and plug this into the formula for the area of the circle having this radius.
Please feel free to post your work if you get stuck or need further guidance.
dexstarr said:
Hey Everyone,
I'd advise you to start by drawing out the situation. Call the third length of your triangle [math]\displaystyle \begin{align*} x \end{align*}[/math]. Can you find a way to write the radius of your circle in terms of [math]\displaystyle \begin{align*} x \end{align*}[/math]?
Also, it might be more useful to use Heron's Formula for the area of a triangle: If your sides are [math]\displaystyle \begin{align*} a,b,c \end{align*}[/math], then the semiperimeter is [math]\displaystyle \begin{align*} s = \frac{a + b + c}{2} \end{align*}[/math] and the area of your triangle is [math]\displaystyle \begin{align*} A = \sqrt{ s ( s - a)( s- b) (s - c)} \end{align*}[/math].
s = (2 + x)/(2) or (1 + x/2)
r^2 = [((1 + x/2)-1)((1 + x/2)-1)((1 + x/2)-x)] / (1 + x/2)
r^2 = (2x^2 - x^3) / (4x+8)
r^2 ' = (-x^3-2x^2+4x) / (2x^2+8x+8)
(-x^3-2x^2+4x) / (2x^2+8x+8) = 0
Max is x= -1 + (5)^1/2
Min is x= 0 Is this correct so far?
Your result agrees with the work I did, as your value for $x$ is twice what I found for $b$. I will admit though, that I do not follow what you did to get there.
Hi,
can you post the final answer to this problem so that I can check it with mine?
$$a^2+b^2=1$$
dmireya said:
Hi,
I no longer have my notes on this problem, but if you want to post your work, I will be glad to go over it.
  • · Replies 51 ·
10K
10K
  • · Replies 17 ·
  • · Replies 16 ·
13K
