Maximizing volume of a Square-Based Pyramid?
  • Thread starter Thread starter sidnygte
    Pyramid Volume
The problem involves maximizing the volume of a square-based pyramid constructed from an 8in x 8in piece of paper. The volume is expressed in terms of the base length and height, with participants exploring the relationships between these dimensions.
  • Participants discuss expressing the volume in terms of a single variable, x, and explore the relationships between height and slant length. There are attempts to derive the height from the slant length and base dimensions, leading to questions about the correctness of their expressions and assumptions.
The discussion is ongoing, with participants providing feedback on each other's mathematical expressions and questioning the validity of certain transformations. There is a focus on clarifying the relationships between the variables involved in the volume calculation.
Some participants note potential mistakes in the expressions used for height and slant length, and there is a discussion about the implications of these errors on the overall problem setup. The complexity of the equations and the need for clarity in notation are also highlighted.
sidnygte
I am given an 8in x 8 in piece of paper and I need to build a pyramid with a square base with the greatest volume.
V = 1/3 * x^2 * h
b = base length
h = height length
I'm trying to get everything in terms of x, which is the length of the base of the square I need to make.
The slant length is l
w(length of the entire slant) = 2l + xhttp://i39.tinypic.com/2me4jsw.jpg
Oh and l = h^2 + x^2/2. height squared + one half x^2.
This is an optimization problem, so I put everything in terms of one variable, and then get the derivative
I just don't know if this is the derivative.
http://i44.tinypic.com/2rh07f5.jpg
Hi Sydneygte,
You made a little mistake: It should be (x/2)^2 instead of x^2/2.
Also, type in the expression of the volume in terms of x and its derivative. You picture is not clear.
ehild
ohh that changes it a bit
so h^2 = l^2 - (x/2)^2
so you can square root everything so
h = l - (x/2)? that doesn't seem right
If square roots worked like that, Pythagoras would have been out of business long ago.
Square roots don't work like that.
After all,
9 = 25 - 16 .​
But:
3 ≠ 5 - 4 .​
so what would the equation look like if you were trying to get H to the power of one?
h = sqrt(l^2 - .5x^2)?
It would be:
h = sqrt( l2 - (0.5x)2 )
or equivalently
h = sqrt( l2 - (0.25)x2 )
(That is a lower case L, not a number 1.)
so then the function in terms of x would be
V = 1/3X^2 * sqrt( sqrt(128)-x)^2 - (0.5x)^2) ?
that seems confusing haha. has would I simplify the double square root? Since it is being squared in the inside can I make it into
V = 1/3X^2 * sqrt(128 - X^2 - 0.25X^2)?
You can't do that either .
(a-b)2 ≠ a2 - b2 .
But the following is true:
(a-b)2 = a2 -2ab + b2
You will still have a square root if you "FOIL" ( sqrt(128)-x)2.
BTW, √(128) = (8)√(2), and either way you write this, it's just a number, there's no variable involved.
Also , you are missing a parenthesis in " sqrt( sqrt(128)-x)^2 - (0.5x)^2) ".
It should be: sqrt( ( sqrt(128)-x)^2 - (0.5x)^2) .
  • · Replies 20 ·
11K
14K
