What Are the Maximum and Minimum Values of y When x^3 is 8+- 2(14)^1/2?
  • Thread starter Thread starter Liang Wei
    Maximum Minimum
The discussion focuses on determining the maximum and minimum values of y when x^3 equals 8 ± 2√14. Participants clarify that the goal is to show these extrema occur at specific x values rather than directly calculating y's maximum and minimum. The first derivative is established as dy/dx = (2y - x^2)/(y^2 - 2x), leading to y = x^2/2. Participants also discuss using the second derivative test and sign tests to confirm the nature of the critical points, ultimately concluding that both x values yield local minima. The conversation emphasizes the importance of correctly deriving x values from the given equations to demonstrate the required maxima and minima for y.
  • #31
In the first line of the image in post #21, while finding the second derivative, you have written -2x instead of y^2-2x
  • #32
Erm I have found my mistakes and able to show it but an additional question is can I use the sign test to find the maximum and minimum values from this kind of equation?sorry to bother you and thanks.
  • #33
You mean the second derivative test? It says only if the point is maxima or minima. It doesn't give you the value.
  • #34
Sign test is a test which you use a value which lies inside the interval of a variable,example x then substitute it into dy/dx to find the sign and we can find the maxima and minima.but anyways I manage to prove it by using 2nd derivative but not sure correct or wrong.
  • #35
Oh that one, for that you need to know the interval, and it requires you to solve for x.
Correct as long as you don't assume the values of x with a calculator and as long as y has both maxima and minima.
  • #36
Ok thanks
  • · Replies 28 ·
  • · Replies 18 ·
