Maximum compression of the spring
The discussion revolves around a physics problem involving two blocks and a spring, focusing on maximum spring compression and the subsequent velocities after a collision. The spring constant is determined to be k = mg/d, and the maximum compression occurs when both blocks share the same velocity. The conservation of energy and momentum equations are crucial for solving the problem, particularly in calculating the maximum compression and the velocity of block II post-collision. The user initially struggled with the algebra but ultimately resolved the issue, confirming the correct answer aligns with the expected result of SQRT(2D/3g)Vo. The conversation highlights the importance of careful algebraic manipulation in physics problem-solving.
aznboi855
The two blocks I and II shown above have mass of m and 2m respectively. Block II as an ideal massless spring attached to one side. When block I is placed on the spring as shown in figure (a), the spring is compressed a distance D at equilibrium. Express your answer to all parts of this question in terms of the given quantities and the physical constants.
a) Determine the spring constant of the spring.
Latter the two blocks are on frictionless horizontal surface. Block II is stationary and block I approaches with the speed of V, as shown in the figure b,c,d.
b) The spring compression is a maximum when the blocks have the same velocity. Briefly explain why is this so.
c) Determine the maximum compression of the spring during the collision.
d) Determine the velocity of the block II after the collision, when block I has separated from the spring.
F = kd
conservation of energy equation
I have already solved for a), which came out to be k = mg/d.
For c), i used the conservation of energy equation and it came out like this :
PEspi + KEi = PEspf + KEf
(1/2)mvi^2 = (1/2)kx^2 + (1/2)3mvf^2
This is where I'm stuck, I know the answer comes out to be SQRT(2D/3g)Vo, but i can't get there.
You need another equation. And an obvious one can be obtained by thinking about linear momentum of the blocks.
Thanks for the reply, I just checked in my book and it also said to use the conservation of momentum equation. Solving for vf, I ended up with:
vf = mvi/3m
plugging it back into the energy equation still doesn't yield the result :(, unless I'm doing it wrong somewhere.
I think you are. Just double checked it and the equations do yield the answer you mentioned in the first post
Nvm, I figured it out, just had some bad algebra.
