Maximum flux in a single phase transformer
The discussion revolves around the calculations related to a single phase transformer, specifically focusing on determining the maximum flux and related parameters such as secondary turns, rated currents, and cross-sectional area of the core. Participants engage with concepts from electromagnetic induction and transformer theory.
  • One participant requests assistance with calculating the maximum flux and cross-sectional area of a transformer core, given its specifications.
  • Another participant references Faraday's law of induction, suggesting a relationship between electromotive force (emf) and the rate of change of magnetic flux.
  • A follow-up question seeks clarification on the equation related to emf and its implications for maximum flux.
  • Further discussion includes the relationship between frequency and time in the context of emf, with some uncertainty expressed about the conditions under which maximum flux occurs.
  • One participant proposes a formula for calculating magnetic flux based on voltage and turns, while also addressing the average voltage consideration.
  • Another participant challenges the accuracy of the previous explanation, asserting that flux linkage is the integral of voltage rather than a simple multiplication of volts and time.
  • There is a debate about the clarity and educational value of using certain mathematical concepts, with some participants advocating for a more intuitive understanding of the underlying physics.
  • One participant provides a formula for maximum flux, indicating a potential method for calculating it based on transformer parameters.
Participants express differing views on the interpretation of mathematical relationships in transformer theory, particularly regarding the integration of voltage and the meaning of flux linkage. There is no consensus on the best approach to explaining these concepts, and the discussion remains unresolved.
Participants highlight limitations in understanding the mathematical formulations and their applicability to different waveform types, indicating a need for clarity in definitions and assumptions used in calculations.
bensm0
A single phase transformer has the following rating: 120 kVA, 2000 V/100 V, 60 Hz with 1000 primary turns.
Determine:
(a) the secondary turns
(b) the rated primary and secondary currents
(c) the maximum flux
(d) given a maximum flux density of 0.25 T, the cross-sectional area of the core.
I have answers for A and B, I'm struggling with C and D! Any help greatly appreciated!
Could you explain that equation please?
The negative of the time-rate of change of magnetic flux per winding turn, multiplied by the number of turns, equals the electromotive force applied to those turns.
Otherwise known as Faraday's law of induction. Very famous ...
Is dt going to be the reciprocal of the frequency? And will EMF be zero for max flux occurs when transformer is idle? I'm still unsure.
Suppose you have a cosinusoidal voltage V=Vmax*cos(wt). What would be the equation of the flux using this EMF in Faraday's law? What is the magnitude of this flux waveform in terms of V?
emf = V = -Ndφ/dt
Oh sorry I didn't realize you were not the questioner.
To be fair, Greek lettered equations usually confuse me at first glance too! Clearer to state just in plain english sometimes! Here is the same again, transliterated:
Magnetic flux (Weber) is the Volts multiplied by [integrated over] the time, divided by the turns.
Or in 'simplified algebra';
Wb=V.s/[turns]
Bear in mind you have to take the average Volts in this formula (Av:RMS = ~1.11) [because we integrate over time], plus the flux is two sided (+ and - flux in each half cycle). (The formula above works fine if you are working with square waves only, but doesn't account for integrating the Volts over the time period being calculated for.)
Also, the 's' is just a half cycle, so if you want to use frequency directly you get the 4.44 term, as used below (2 x 2 x 1.11).
So, as for the cross-sectional area (T=Wb/A), this is generally approximated to the following formula:
T(Peak Flux density, Teslas)=VRMS/{4.44 x frequency x cross-section x turns}
This is false.
1) The flux linkage is the integral of voltage, not volts multiplied by time. If you do the time integral of the previous voltage waveform, the magnitude of this waveform is the answer to the poster's question. Flux is simply the flux linkage divided by the number of turns.
2) Never answer an homework type question, you have to let them work it out.
Mbert said:
This is false.
Well, to be pedantic, I would say the 'integral of voltage' is physically meaningless, so why use it as a concept in an educational setting? What we are looking at is the rate of change of flux is the Volts/turn at any instant. I'd says any other conclusions are just mathematical machinations after that that don't add much to comprehension of the concepts, which are difficult enough to graps before turning it into pure maths.
I am unclear what you are saying is 'false'. We do not seem to be disagreeing.
(I made mods to #8, to clarify on your point.)
No-one has, yet. I've only sought to provide the basic simplified equations that practical transformer-builders use.
I agree, but if the goal is comprehension of the concepts, then why give the formula (that only works out for a given voltage waveform)? Understanding where that formula comes from is the key in understanding, rather than "plug-and-play".
If the question is about transformer engineering, obviously the author is familiar with integrals. The term "rate of change" is precisely the definition of the derivative. I'm not sure if there is an analog term for the integral, but perhaps it is best to talk about "surface under the waveform", instead of Volts*time. The former is only true for a DC waveform, which we would obviously not like to put on the transformer.
I can answer your question. The formula for Maximum flux = V1= 4.44F∅N1 or V2=4.44F∅N2. Hope that does helps.
22K
