Maxwell relations Thermodynamics
The discussion revolves around demonstrating a relationship in thermodynamics related to Maxwell's relations, specifically the equality of certain partial derivatives involving temperature, pressure, and entropy. The context is rooted in the study of internal energy as a function of entropy and volume.
  • Participants explore the relationship between the partial derivatives of temperature and pressure, questioning the validity of the Schwartz relation and the continuity of internal energy. There are attempts to manipulate equations to demonstrate the equality of these derivatives.
Participants are actively engaging with the problem, with some providing insights on the commutativity of second partial derivatives. There is a focus on the need to justify assumptions about the continuity of internal energy, with some suggesting that experimental evidence may serve as a form of proof.
There is an ongoing discussion about the necessity of justifying the assumption that internal energy is a continuous function, particularly in the context of an exam setting. The participants express uncertainty about how to formally prove this continuity without relying on established knowledge.
thonwer
Show that: [itex](\frac{∂T} {∂V})_S,_n=-(\frac {∂P} {∂S})_V,_n[/itex]
[itex]dU=TdS-PdV+μdn[/itex]
[itex]\frac {∂} {∂S} (\frac{∂U} {∂V})_S,_n=-(\frac {∂P} {∂S})_V,_n[/itex]
[itex]\frac {∂} {∂V} (\frac{∂U} {∂S})_V,_n=(\frac{∂T} {∂V})_S,_n[/itex]
I tried to isolate T and P, but I get stuck:
[itex]TdS=dU+PdV[/itex]
[itex]-PdV=dU-TdS[/itex]
How can I demonstrate that they are equal?
It looks like you already had it in your first two equations of Attempt at a Solution. You are aware that 2nd partial derivatives with respect to two variables are interchangeable (commutative), correct?
Chet
Yes I see that, but I ment to obtain [itex]−(\frac {∂P} {∂S})_V,_n[/itex] from [itex](\frac {∂T} {∂V})_S,_n[/itex] or viceversa, demonstrating Schwartz relation in some way.
thonwer said:
Yes I see that, but I ment to obtain [itex]−(\frac {∂P} {∂S})_V,_n[/itex] from [itex](\frac {∂T} {∂V})_S,_n[/itex] or viceversa.
Isn't that what your first two equations under Attempt demonstrate?
Chet
If I say they are equal, I am assuming that Schwartz relation is valid in this case, or that U is a continuos function. I want to demonstrate why Schwartz relation is valid.
What's wrong with assuming that U is a continuous function for a single-component single-phase material?
Chet
Nothing, but in an exam I would have to reason why I assume that U is continuous, so if I could go from [itex]-\left( {\frac{\partial P} {\partial S}}\right)_{V,n}[/itex] to [itex]\left( {\frac{\partial T} {\partial V}}\right)_{S,n}[/itex] by using derivatives and their properties, the problem would be solved I think.
Why would you think it's not continuous?
Chet
I think it's continuous, I know from theory, but it's not a given in the problem, so if i use it, I have to say why. As I don't know how to justify that U is continuous, I think that, if I can demonstrate that Schwartz relation is valid, then, I can avoid justifying its continuity.
I don't know what to say. Are you a mathematician or a physicist? If the latter, why would you think that internal energy is not a continuous function of entropy and volume?
Chet
I'm studying Physics, and I know it is a continuous function of entropy and volume, but one thing is knowing and another is proving. I need to prove this knowledge.
It's observed experimentally. Does that count as proof? Otherwise you need to start looking into statistical thermo.
Chet
Mmm statiscal thermo is a subject I will study next year, so if there's no other proof I suppose experimental proof is what I need.Thank you.
  • · Replies 19 ·
