Maxwell Stress Tensor: Engineering Question Answered
The discussion centers on the application of the Maxwell Stress Tensor (MST) in calculating torque on a rotor in electric motors, particularly when the airgap remains constant while the magnetic circuit length varies. The consensus is that the MST primarily addresses linear momentum rather than angular momentum, making it unsuitable for direct torque calculations. However, it can be used to compute linear forces, which can then be converted to torque based on the geometry of the system. The conversation highlights the importance of understanding the relationship between torque, airgap changes, and magnetic circuit adjustments in motor design.
  • Understanding of Maxwell Stress Tensor and its applications in electromagnetism
  • Familiarity with torque and angular momentum concepts in physics
  • Knowledge of Lagrangian mechanics and conservation laws
  • Basic principles of electromagnetic simulation software
  • Study the application of Maxwell Stress Tensor in electromagnetic simulation packages
  • Explore Lagrangian density in electromagnetic fields for torque calculations
  • Research the relationship between airgap changes and torque in electric motors
  • Learn about tensor calculus and its applications in electrical engineering
Electrical engineers, physicists, and students interested in the theoretical aspects of motor design and torque calculations using advanced electromagnetism concepts.
mind_inertia
Hello!
I was talking with a friend today about electrical motors and we started talking about theoretical designs. One question came up which was could the Maxwell Stress Tensor be used to calculate the torque on a rotor of a motor where the airgap is held constant and the magnetic circuit length changes instead of the airgap like motors are designed with.
Could someone who is more physics savy than myself answer my theoretical engineering question?
I had a quick look. Here is what I think. Stress tensor arises as a result of invariance with respect to translations. So it contains linear momentum density flow (momentum and energy).
Torque is the rate of change of angular momentum. Angular momentum conservation corresponds to invariance with respect to rotations. So you need to go back to the Lagrangian density of the electromagnetic field and see what conservation law you get if you consider invariance under rotations. This will give you the current for the flow of angular momentum density, and this will give you the torque.
So in short. My answer is no. Maxwell stress tensor is for linear momentum, not angular one. But I could be wrong as this is the first time I did this rough calculation.
Of course what is possible, is to calculate linear force based on Maxwell Stress Tensor, and then convert it to torque through knowledge of the geometry of the object. I.e. if you find that field exerts more linear force on one of the stick, the stick will start spinning. This will allow you to find the torque
Thank you for your analysis Cryo! In electromagnetic simulation packages the Maxwell Stress Tensor is industry standard to calculate torques but from your answer I feel you are saying that Torques shouldn't be able to be calculated from the Maxwell Stress Tensor. Do I understand you correctly?
If so I wish to highlight the focus of my question. The torque of an electric motor is related to the change of airgap, the motor moves to minimize reluctance by shortening the air gap. Another method of minimizing reluctance and thereby deriving motion is by changing the effective magnetic circuit length. I feel that the MST should be able to calculate it but since this is a theoretical problem I thought it is best to approach physicists, particularly because I am unsure of how to use Tensors effectively on paper. I am slowly digesting the works of Kron in regards to applying Tensors to electrical engineering problems but it's a slow journey for me!
Thanks again.
